Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Inserting Image
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Inserting Image (Read 1738 times)
squirreldip
Newt
WWW
Inserting Image
on:
November 21, 2017, 12:08:46 PM »
Back in the 'old' days when you imported an image in came in as a block with coloured 2d solids. Is it possible to import using this method with current versions? If not, is anyone aware of a utility to do so?
Logged
Needs a day job
Re: Inserting Image
Reply #1 on:
November 21, 2017, 12:24:24 PM »
Adobe Illustrator can export images to DWG.
Logged
squirreldip
Newt
WWW
Re: Inserting Image
Reply #2 on:
November 21, 2017, 12:50:00 PM »
I don't have access to Illustrator... I'm trying to write a routine that will read the 'pixels'
Another option (which is likely a better idea) is to use Visual Studio and write the data I want to a file.
Logged
d2010
Bull Frog
WWW
Re: Inserting Image
Reply #3 on:
November 21, 2017, 06:18:19 PM »
You found one solution
http://lisp2arx.3xforum.ro
Edit by Admin
Are you fishing?
Last Edit: December 18, 2017, 12:28:04 PM by d2010
Logged
roy_043
Water Moccasin
BricsCAD 18
Re: Inserting Image
Reply #4 on:
November 22, 2017, 10:19:13 AM »
If you save the image as a .bmp file with a color depth of 256 (8 bits), then every pixel will be represented by 1 byte in the file. The first part of the file defines the X and Y size of the image, the palette etc. then all 'pixel bytes' follow in sequence.
For images with a limited palette this is doable:
Save as BMP with a color depth of 256.
Read the BMP with a binary read Lisp function. This should return a list of integers.
Using the X and Y size calculate the total number of pixels and remove the bytes of the header from the list.
Turn the list into a list of lists using the X size.
Manually change the integers to color values.
Logged
squirreldip
Newt
WWW
Re: Inserting Image
Reply #5 on:
November 27, 2017, 12:56:21 PM »
Thanks for the comments!
I think I found the simplest solution and it was to use Visual Studio Community - fairly easy to work with graphics file and I can output text in whatever structure I want to.
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Inserting Image
