I have a framing elevation and I want to show a horizontal section (basically a detail plan view of an area, but created with a rotated section cut)..
The problem is, the view will not show items that pass through the section marker.
It's acting like an elevation marker, but I want to see the columns that are "Cut" (pass through section marker).
I have verified all visibility settings, work sets, filters everything.
I did notice if I change the detail level to "course" I do see the columns.
I also notice if I simply move the marker "above" the items, I can see them, so I suspect it's something to do with the section marker behavior.
(see screen shot, thanks in advance!)
(Revit - Structure 2017
