Author Topic: Create block using hatch  (Read 5024 times)
David Hall
  • Automatic Duh Generator
« on: November 15, 2017, 07:25:16 PM »
I am trying to help a friend with this code.  They can draw the Texas flag using 2 picked points, but would like to make a block out of the result.  I cant figure it out.
Option Explicit
Public Sub DrawTexasFlagOp()
Dim PT1 As Variant
Dim PT2 As Variant
Dim pntLL(0 To 2) As Double
Dim pntLR(0 To 2) As Double
Dim pntUL(0 To 2) As Double
Dim pntUR(0 To 2) As Double
Dim pntLRBlue(0 To 2) As Double
Dim pntURBlue(0 To 2) As Double
Dim vertDist As Double
Dim horzDist As Double
Dim pntRW_Left(0 To 2) As Double
Dim pntRW_Right(0 To 2) As Double
Dim circleDiameter As Double
Dim cntPnt(0 To 2) As Double
Dim cir As AcadCircle
Dim starTopPoint(0 To 2) As Double
' star leg length @ unit circle of 1 = .7265
' starlegLength is variable
Dim starLegLen As Double
Dim starLegStart As Variant
Dim starLegEnd As Variant
PT1 = ThisDrawing.Utility.GetPoint(, "Pick lower left corner of Flag")
vertDist = ThisDrawing.Utility.GetDistance(PT1, vbCr & "Pick distance for vertical")
horzDist = (vertDist / 2) * 3
pntLL(0) = PT1(0) 'X value
pntLL(1) = PT1(1) 'Y value
pntUL(0) = PT1(0)
pntUL(1) = PT1(1) + vertDist
pntLR(0) = PT1(0) + horzDist
pntLR(1) = PT1(1)
pntUR(0) = PT1(0) + horzDist
pntUR(1) = PT1(1) + vertDist
pntLRBlue(0) = pntLL(0) + (horzDist / 3)
pntLRBlue(1) = pntLL(1)
pntURBlue(0) = pntLL(0) + (horzDist / 3)
pntURBlue(1) = pntLL(1) + vertDist
pntRW_Left(0) = pntLRBlue(0)
pntRW_Left(1) = pntLRBlue(1) + (vertDist / 2)
pntRW_Right(0) = pntLR(0)
pntRW_Right(1) = pntRW_Left(1)
circleDiameter = (horzDist / 3) * 0.75
cntPnt(0) = pntLL(0) + horzDist / 6
cntPnt(1) = pntLL(1) + vertDist / 2
starTopPoint(0) = cntPnt(0)
starTopPoint(1) = cntPnt(1) + (circleDiameter / 2)
starLegLen = 0.7265 * (circleDiameter / 2)
Dim plineObjStar As AcadLWPolyline
Dim pointsStar(0 To 21) As Double
starLegStart = starTopPoint
starLegEnd = ThisDrawing.Utility.PolarPoint(starLegStart, dtor(288), starLegLen)
pointsStar(0) = starTopPoint(0)
pointsStar(1) = starTopPoint(1)
pointsStar(2) = starLegEnd(0)
pointsStar(3) = starLegEnd(1)
starLegStart = starLegEnd
starLegEnd = ThisDrawing.Utility.PolarPoint(starLegStart, dtor(0), starLegLen)
pointsStar(4) = starLegEnd(0)
pointsStar(5) = starLegEnd(1)
starLegEnd = ThisDrawing.Utility.PolarPoint(starLegStart, dtor(216), starLegLen)
pointsStar(6) = starLegEnd(0)
pointsStar(7) = starLegEnd(1)
pointsStar(8) = starLegEnd(0)
pointsStar(9) = starLegEnd(1)
starLegEnd = ThisDrawing.Utility.PolarPoint(starLegStart, dtor(144), starLegLen)
pointsStar(10) = starLegEnd(0)
pointsStar(11) = starLegEnd(1)
pointsStar(12) = starLegEnd(0)
pointsStar(13) = starLegEnd(1)
starLegEnd = ThisDrawing.Utility.PolarPoint(starLegStart, dtor(72), starLegLen)
pointsStar(14) = starLegEnd(0)
pointsStar(15) = starLegEnd(1)
pointsStar(16) = starLegEnd(0)
pointsStar(17) = starLegEnd(1)
pointsStar(18) = starLegEnd(0)
pointsStar(19) = starLegEnd(1)
pointsStar(20) = starTopPoint(0)
pointsStar(21) = starTopPoint(1)
Dim mylayer As AcadLayer
Set mylayer = ThisDrawing.Layers.Add("RED")
mylayer.color = acRed
Set mylayer = ThisDrawing.Layers.Add("WHITE")
mylayer.color = acWhite
Set mylayer = ThisDrawing.Layers.Add("BLUE")
mylayer.color = acBlue
Set mylayer = ThisDrawing.Layers.Item("RED")
ThisDrawing.ActiveLayer = ThisDrawing.Layers.Item("0")
Dim hatchObj As AcadHatch
Dim hatchObj2 As AcadHatch
Dim hatchObj3 As AcadHatch ' blue
Dim hatchobj4 As AcadHatch
  Dim patternName As String
  Dim PatternType As Long
  Dim bAssociativity As Boolean
  ' Define the hatch
  patternName = "SOLID"
  PatternType = 0
  bAssociativity = True
  Set hatchObj = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
Dim plineObj As AcadLWPolyline
  Dim points(0 To 9) As Double
    points(0) = pntRW_Left(0)
    points(1) = pntRW_Left(1)
    points(2) = pntRW_Right(0)
    points(3) = pntRW_Right(1)
    points(4) = pntUR(0)
    points(5) = pntUR(1)
    points(6) = pntURBlue(0)
    points(7) = pntURBlue(1)
    points(8) = pntRW_Left(0)
    points(9) = pntRW_Left(1)
Set plineObj = ThisDrawing.ModelSpace.AddLightWeightPolyline(points)
plineObj.Closed = False
Dim outerLoop As Variant
Dim outerLoopArray(0) As Object
Set outerLoopArray(0) = plineObj
outerLoop = outerLoopArray
hatchObj.AppendOuterLoop (outerLoop)
hatchObj.Layer = "WHITE"
hatchObj.Evaluate
plineObj.Delete  ' white hatch polyline
ThisDrawing.Regen True
'create red hatch pline
    points(4) = pntLR(0)
    points(5) = pntLR(1)
    points(6) = pntLRBlue(0)
    points(7) = pntLRBlue(1)
Set hatchObj2 = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
hatchObj2.AppendOuterLoop (outerLoop)
hatchObj2.Layer = "red"
hatchObj2.Evaluate
plineObj.Delete  ' red hatch polyline
points(0) = pntLL(0)
    points(1) = pntLL(1)
    points(2) = pntUL(0)
    points(3) = pntUL(1)
    points(4) = pntURBlue(0)
    points(5) = pntURBlue(1)
    points(8) = pntLL(0)
    points(9) = pntLL(1)
Set plineObjStar = ThisDrawing.ModelSpace.AddLightWeightPolyline(pointsStar)
Dim innerLoop As Variant
Dim innerLoopArray(0) As Object
Set innerLoopArray(0) = plineObjStar
innerLoop = innerLoopArray
Set hatchObj3 = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
hatchObj3.AppendOuterLoop (outerLoop)
hatchObj3.AppendInnerLoop (innerLoop)
hatchObj3.Layer = "blue"
hatchObj3.Evaluate
Set hatchobj4 = ThisDrawing.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
hatchobj4.AppendOuterLoop (innerLoop)
hatchobj4.Layer = "white"
hatchobj4.Evaluate
plineObjStar.Delete
End Sub
Private Function rtod(r As Double)
rtod = (r * 180) / 3.14159265358979
End Function
Private Function dtor(d As Double)
dtor = (d * 3.14159265358979) / 180
End Function
RICVBA
Re: Create block using hatch
« Reply #1 on: November 16, 2017, 06:22:09 AM »
you have to:
1) insert a new Block object
2) "Add" all graphic elements (hatches, LWPolys) to this newly created block, instead of to the drawing modelspace
3) insert a block reference of the new block in the drawing modelspace
so the changes to your code are minimal, as outlined by comments in the following:
Option Explicit
    Dim PT1 As Variant
    Dim PT2 As Variant
    pntUL(0) = PT1(0)
    pntLR(1) = PT1(1)
    ' Define the block
    Dim flagBlock As AcadBlock
    Set flagBlock = ThisDrawing.Blocks.Add(PT1, "FlagBlock")
    With flagBlock '<--| reference the new block for all subsequent "Add" methods
        ' Define the hatch
        PatternType = 0
        Set hatchObj = .AddHatch(PatternType, patternName, bAssociativity) '<--| .AddHatch will add a hatch to the referenced block, instead of to the drawing modelspace
        Set plineObj = .AddLightWeightPolyline(points) '<--| .AddLightWeightPolyline will add a LWPoly to the referenced block, instead of to the drawing modelspace
        hatchObj.Evaluate
        Set plineObj = .AddLightWeightPolyline(points) '<--| see above comments
        Set hatchObj2 = .AddHatch(PatternType, patternName, bAssociativity) '<--| see above comments
        hatchObj2.Evaluate
        Set plineObjStar = .AddLightWeightPolyline(pointsStar) '<--| see above comments
        Set hatchObj3 = .AddHatch(PatternType, patternName, bAssociativity) '<--| see above comments
        hatchObj3.Evaluate
        Set hatchobj4 = .AddHatch(PatternType, patternName, bAssociativity) '<--| see above comments
        hatchobj4.Evaluate
        plineObjStar.Delete
    End With
    ' Insert the block
    Dim blockRefObj As AcadBlockReference
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(PT1, "FlagBlock", 1#, 1#, 1#, 0)
    ZoomAll
End Sub
End Function
End Function
David Hall
« Reply #2 on: November 16, 2017, 08:06:21 AM »
Thanks.  I could not figure that one out.  It's been to long since I programmed AutoCAD
RICVBA
« Reply #3 on: November 16, 2017, 09:11:14 AM »
you are welcome
