The entire label itself exists on a layer*, and then the components of the label can be on other layers.
* This is the Object Layer, defined in "Edit Drawing Settings>Object Layers"
It's just like inserting a block. The block can be inserted on layer "A", but components of the block can be on layer "0", "1", "B", etc.
uh, not to contradict, but where does one place the individual label component(s) on their own layer?
I've not encounter that setting...
YES Object Layers....says place these things Alignments for example on a specific layer...
and Alignment Labels go on a specific layer....
However I haven't seen or been able to place things like the station ticks on one layer and the station text on another.
Where does that get controlled?
