Author Topic: On a bias..  (Read 4265 times)
Water Bear
On a bias..
« on: January 07, 2004, 10:24:00 AM »
Can anyone see why this routine prints what I want, but I can't seem to justify the text
(defun elvcalc ()
  (setq oldunits (getvar "lunits"))
  (setvar "lunits" 5)
  (setq #wid1  (getreal "\nEnter duct WIDTH: ")
#dep1  (getreal "\nEnter duct DEPTH: ")
#bod   (getstring "\nEnter BOTTOM elevation: ")
#conn1 (strcat "\n" (rtos #wid1) " X " (rtos #dep1))
  ;;convert elev from string to REAL calc top & bot elev
  (setq #bod (distof #bod 4))
  ;;calc top & center elev using REALS
  (setq #tod (+ #bod #dep1)
#cod (+ #bod (/ #dep1 2))
  ;;convert REALS back to strings, add plus signs(will only be used in tags, not for calc)
  (setq #tod (strcat "\nT+ " (rtos #tod 4 2))
#cod (strcat "\nC+ " (rtos #cod 4 2))
#bod (strcat "\nB+ " (rtos #bod 4 2))
  (setq elv_text (strcat #conn1 #tod #cod #bod))
  (princ #tod)
  (princ #cod)
  (princ #bod)
  (princ #conn1)
  (setq elvpnt (getpoint "\nSelect point to insert Elevation text:  "))
  (if (null (tblsearch "style" "duc_el"))
    (command "style" "duct_el" "romans" "2" "" "20" "" "" "")
  (command "layer" "m" "SM-Duct Elevations" "c" "4" "" "")
  (command "text" "s" "duct_el" "bl" elvpnt 0 elv_text)
  (setvar "lunits" oldunits)
  ) ;end defun
SMadsen
On a bias..
« Reply #1 on: January 08, 2004, 06:47:27 AM »
I wonder if anyone ever intended for text to contain newline characters. At least it seems to be the standard behavior to indent the new lines of text and I don't think there's a way to change the feature. Could be terribly wrong on that, though!
Why don't you use MTEXT instead (insert /P codes for newline instead of \n)? Or maybe multiple lines of TEXT?
Just a side note: Beware of the variable #conn1 in your code. It seems to be a global that might happened to be assigned by luck during your test runs.
Anonymous
mtext
« Reply #2 on: January 08, 2004, 10:52:25 AM »
Thanks Smadsen...I'd actually been trying that before your post. I changed it to this:
(command "-mtext" pause "r" (rtd #trav) pause #conn1 #tod #cod #bod "")But I think I'm using an improper syntax because although it accomplishes the task...the menuecho doesn't look right
deegeecees
On a bias..
« Reply #3 on: January 08, 2004, 11:03:05 AM »
Try echoing, then inserting the pcodes.
SMadsen
On a bias..
« Reply #4 on: January 08, 2004, 11:30:25 AM »
Water Bear,
How about constructing the text before you call the MTEXT command. To determine the size of the text box, you can use TEXTBOX like shown below and try to fit it with some approximate factors. Here I've just used 1.5 times the width and six times the height. You can change it to whatever you think is appropriate but asking the user for anything but the insertion point isn't fair, I think.
(defun elvcalc (/ #bod #cod #conn1 #dep1 #tod #wid1 elvpnt elv_text oldunits txtbox)
  (setvar "lunits" 5)
        ;;changed this to GETREAL (just for the heck of it)
        #bod  (getreal "\nEnter BOTTOM elevation: ")
  ;;(setq #bod (distof #bod 4))
  ;;added some error stuff (just for the heck of it):
    ((apply 'and (mapcar 'numberp (list #wid1 #dep1 #bod)))
     (setq #conn1 (strcat (rtos #wid1) " X " (rtos #dep1)))
     (setq #tod (strcat "T+ " (rtos #tod 4 2))
           #cod (strcat "C+ " (rtos #cod 4 2))
           #bod (strcat "B+ " (rtos #bod 4 2))
     (setq elv_text (strcat #conn1 "\\P" #tod "\\P" #cod "\\P" #bod))
     (setq txtbox (textbox (list (cons 1 elv_text))))
     (princ #tod)
     (princ #cod)
     (princ #bod)
     (princ #conn1)
     ;;added some extra reassuring (just for .. of it)
       ((and txtbox (setq elvpnt (getpoint "\nSelect point to insert Elevation text:  ")))
        (command "-mtext"
                 elvpnt
                 (list (+ (car elvpnt) (* 1.5 (- (caadr txtbox) (caar txtbox))))
                       (+ (cadr elvpnt) (* 6.0 (- (cadadr txtbox)) (cadar txtbox)))
                       (caddr elvpnt)
                 elv_text
) ;_ end defun
On a bias..
« Reply #5 on: January 08, 2004, 11:32:59 AM »
Try this :
(defun elvcalc ()
  (setvar "lunits" 5)
  (princ #tod)
  (princ #cod)
  (princ #bod)
  (princ #conn1)
  (if elvpnt ; make 2D point
    (setq elvpnt (list (car elvpnt) (cadr elvpnt)))
  (command "-mtext" elvpnt "s" "duct_el" "W" 0  #conn1 #tod #cod #bod "")
  )               ;end defun
Water Bear
eagle ayes...
« Reply #6 on: January 08, 2004, 07:31:07 PM »
thanks for the help...
And you were right about that global #conn1...!
