Author Topic: Rotating stationing  (Read 2495 times)
PHX cadie
Rotating stationing
« on: October 31, 2017, 10:21:37 PM »
I have an alignment that basically runs north-south. I've used the company label style, but since we are starting on the north end I need the text rotated 180 about the tick. I've tried every multiple of 90 degrees in the rotation angle, but its always the wrong way or perp with the align. The preview is what I would like, but my stationing is 180 out
What am I doing wrong?
hope the attach is not super huge :(
(my 1st "company" C3D)......Arrrrrrr
« Last Edit: October 31, 2017, 11:04:07 PM by PHX cadie »
Acad 2013 and XM
Re: Rotating stationing
« Reply #1 on: November 01, 2017, 07:05:58 AM »
Look at the other GENERAL TAB and check to see if your label is set to be Plan Readable
also verify its Anchor Point and Anchor Component
PHX cadie
« Reply #2 on: November 01, 2017, 10:19:02 AM »
Plan Readable   :)
Thank u Sir!
Acad 2013 and XM
