I noticed a strange behavior of a vlisp instruction.
![nerdyembarassed :nerdyembarassed:](http://www.theswamp.org/Smileys/black/nerdyembarassed.gif)
I wrote a set of instructions for inserting blocks into the paper space of a layout, visualized by it's extension:
(command-s "_-insert" bl$ "_sc" scbl# ptbl 0)
I had previously set the 'OSMODE system variable to 0 or 16384, but in some cases the insertion point of the block moved to the nearby line or block.
The only method I have come up with is to first launch a zoom command, narrowed at the insertion point or at a far point, with a factor of 30 or less.
Does anyone know the reason for such behavior?
