Author Topic: get ploter's all papersizes very slow?  (Read 1391 times)
xinxirong
  • Mosquito
« on: October 24, 2017, 11:20:28 PM »
vla-put-CanonicalMediaName then vla-GetPaperSize,I could get one papersize within 3 second。But get all the papersizes will take almost more than 1 minute。
PS. the ploter is network printer
ChrisCarlson
Re: get ploter's all papersizes very slow?
« Reply #1 on: October 25, 2017, 02:51:19 PM »
Check the driver for the plotter. There might be a newer or better version you can use. We have a similar scenario with the driver that Windows finds for our KIP is ungodly slow but the driver from KIP runs as it should.
dgorsman
« Reply #2 on: October 26, 2017, 10:57:45 AM »
Printers support way more paper sizes than are actually used (not to mention, actually loaded in the physical device), and the names don't change.  Find the ones you use (most likely, just 11x17 and letter) and hard code the canonical names.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
xinxirong
  • Mosquito
« Reply #3 on: November 06, 2017, 06:27:37 AM »
YES,you're right,my OCE TDS750 is slow,and Teriostar 1030 is quick
