Author Topic: SSGET Text Unformat  (Read 1488 times)
mailmaverick
SSGET Text Unformat
« on: September 28, 2017, 10:03:32 AM »
I want to make selection set of all Texts in Drawing Starting from Keyword kwrd .
I am using :
(ssget "_x" (list (cons 0 "*TEXT") (cons 1 (strcat kwrd "*"))))It does not select texts in which formatting codes such as /U /T etc are present in the beginning.
How to remove text formatting codes in ssget ?
Re: SSGET Text Unformat
« Reply #1 on: September 28, 2017, 10:14:40 AM »
  1. (ssget "_x" (list '(0 . "*TEXT") (cons 1 (strcat "*" kwrd "*"))))
« Last Edit: September 28, 2017, 10:50:07 AM by ronjonp »
mailmaverick
« Reply #2 on: September 28, 2017, 10:32:23 AM »
Thanks for prompt reply but it will select all texts containing other than formatting codes in the beginning.
For example i want that "{\\fArial Narrow|b1|i0|c0|p34;\\LD12}" must be selected but "dffDdfdf" should not be selected.
I want to select only those texts which either start from kword or start from 'formatting codes' followed directly by kword.
« Last Edit: September 28, 2017, 10:35:53 AM by mailmaverick »
« Reply #3 on: September 28, 2017, 10:50:52 AM »
Maybe:
  1. (ssget "_x"
  2.        (list '(0 . "*TEXT") (cons 1 (strcat kwrd "*,{\\*;" kwrd "*," kwrd "*,{\\*;\\*" kwrd "*")))
  3. )
« Last Edit: September 28, 2017, 10:59:57 AM by ronjonp »
