Author Topic: Transient code works in acad, not in bricscad  (Read 3206 times)
jmaeding
« on: September 27, 2017, 04:43:32 PM »
I did a test prog to draw a fence on screen as the user picks.
It works fine in autocad, but not in bricscad v16. I will try on V17 soon.
Here is the code, very typical of example routines that use point monitor.
What you should get is a red polyline being drawn, just like drawing a real pline.
Escape kills it, this is just an example prog.
//C# Usings
using System;
using System.Collections;
using SC = System.Collections;
using SCG = System.Collections.Generic;
using System.Text;
using System.Text.RegularExpressions;
using System.Diagnostics;
using System.IO;
using System.Windows.Forms;
using SWF = System.Windows.Forms;
using System.ComponentModel;
using System.Drawing;
using System.Runtime.InteropServices;
using System.Xml;
using System.Xml.Serialization;
using SM = System.Math;
using System.Linq;
//AutoCad Usings
#if ACAD
using AcAp = Autodesk.AutoCAD.ApplicationServices.Application;
using AcEd = Autodesk.AutoCAD.EditorInput;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcGe = Autodesk.AutoCAD.Geometry;
using AcCo = Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.Windows;
using AcWn = Autodesk.AutoCAD.Windows;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Customization;
#endif
#if BCAD
using Teigha.DatabaseServices;
using AcDb = Teigha.DatabaseServices;
using Bricscad.EditorInput;
using AcEd = Bricscad.EditorInput;
using Teigha.Geometry;
using AcGe = Teigha.Geometry;
using AcCo = Teigha.Colors;
using Teigha.Runtime;
using Teigha.GraphicsInterface;
using Bricscad.Runtime;
using Bricscad.ApplicationServices;
using AcAp = Bricscad.ApplicationServices.Application;
using Bricscad.Windows;
using AcWn = Bricscad.Windows;
#endif
[assembly: CommandClass(typeof(ProgTestingAcad.Program2))]
namespace ProgTestingAcad {
    public class Program2 {
        [CommandMethod("TESTPTS2")]
        public static void GetPts() {
            Document dwg = AcAp.DocumentManager.MdiActiveDocument;
            Editor ed = dwg.Editor;
            MyptCmd cmd = new MyptCmd(dwg);
            cmd.GetPts();
    public class MyptCmd {
        private Document _dwg;
        private Editor _editor;
        private List<Point2d> _points;
        private List<Point2d> _origpoints = new List<Point2d>();
        private Point2d _resPt;
        private AcDb.Polyline _pline = null;
        public MyptCmd(Document dwg) {
            _dwg = dwg;
            _editor = _dwg.Editor;
        public void GetPts() {
            _points = new List<Point2d>();
            //get first point
            PromptPointOptions opt = new PromptPointOptions("\nPick Point: ");
            PromptPointResult res = _editor.GetPoint(opt);
            if (res.Status == PromptStatus.OK) {
                _origpoints.Add(new AcGe.Point2d(res.Value.X, res.Value.Y));
                try {
                    //Handling mouse cursor moving during picking
                    _editor.PointMonitor += new PointMonitorEventHandler(_editor_PointMonitor);
                    bool loop = true;
                    //get more points
                    while (loop) {
                        if (!PickNewPoint())
                            loop = false; //no point
                        else
                            _origpoints.Add(_resPt);
                catch {
                    throw;
                finally {
                    ClearTransientGraphics();
                    //Remove PointMonitor handler
                    _editor.PointMonitor -= new PointMonitorEventHandler(_editor_PointMonitor);
        private bool PickNewPoint() {
                _resPt = new AcGe.Point2d(res.Value.X, res.Value.Y);
                return true;
            else {
                return false;
        private void ClearTransientGraphics() {
            TransientManager.CurrentTransientManager.EraseTransients(
                TransientDrawingMode.DirectShortTerm,
                128, new IntegerCollection());
            if (_pline != null)
                _pline.Dispose();
            _pline = null;
        private void _editor_PointMonitor(object sender, PointMonitorEventArgs e) {
            Point2d pt = new Point2d(e.Context.RawPoint.X, e.Context.RawPoint.Y);
            bool go = true;
            //figure new points
            //set _points to orig and add point
            //we must do this as we cannot simply add a point
            _points.AddRange(_origpoints);
            _points.Add(pt);
            //draw new _pline
            if (go) {
                _pline = new AcDb.Polyline(_points.Count);
                for (int i = 0; i < _points.Count; i++) {
                    _pline.AddVertexAt(i, _points[i], 0.0, 0.0, 0.0);
                _pline.ColorIndex = 1;
                TransientManager.CurrentTransientManager.AddTransient(
                    _pline, TransientDrawingMode.DirectShortTerm, 128
Any ideas?
I tried directTopMost and other ideas, that did not matter.
thx
James Maeding
huiz
  • Certified Prof C3D
Re: Transient code works in acad, not in bricscad
« Reply #1 on: September 27, 2017, 05:09:44 PM »
I noticed BricsCAD V17 does not update a transient entity during a PointMonitor, unless you scroll the mousewheel. Just static transient entities works fine.
The programmers in Gent are aware of it and will examine the possibilities.
jmaeding
« Reply #2 on: September 27, 2017, 05:32:15 PM »
Nooooooooooooooo........
Shoot, I hit a bug?
I did a ton of programming in acad and have tried transients in bcad before so never thought they would misbehave in pointmonitor.
I hope they fix this.
Thanks for the heads up huiz!
James Maeding
huiz
« Reply #3 on: September 28, 2017, 03:57:12 AM »
At least they take it more serious than another CAD software company  ;D
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: September 28, 2017, 09:45:07 AM »
hack alert
Code - C++: [Select]
  1.             if (go)
  2.             {
  3.                 _pline = new AcDb.Polyline(_points.Count);
  4.                 for (int i = 0; i < _points.Count; i++)
  5.                 {
  6.                     _pline.AddVertexAt(i, _points[i], 0.0, 0.0, 0.0);
  7.                 }
  8.                 _pline.ColorIndex = 1;
  9.                 TransientManager.CurrentTransientManager.AddTransient(
  10.                     _pline, TransientDrawingMode.DirectShortTerm, 128
  11.                     , new IntegerCollection());
  12.
  13.                 _editor.SetCurrentView(_editor.GetCurrentView());//<<<----
  14.             }
  15.
edit: needs to be disposed so..
  1.                using (ViewTableRecord rec = _editor.GetCurrentView())
  2.                 {
  3.                     _editor.SetCurrentView(rec);
  4.                 }
  5.
there is probably a better alternative, this seems slightly laggy on large drawings
« Last Edit: September 28, 2017, 06:13:10 PM by nullptr »
jmaeding
« Reply #5 on: September 28, 2017, 01:28:26 PM »
'That is really amazing.' .... 'That really is truly amazing. That is so amazingly amazing I think I'd like to steal it.' -Zaphod Beeblebrox
It works, that was too easy! Thanks a TON for your reply, now my Bricscad stuff works perfect, I owe you!
James Maeding
huiz
« Reply #6 on: October 03, 2017, 07:51:03 AM »
Indeed, perfect! In the AutoCAD variant I did not set the Current View, it works fine that way. If I add the SetCurrentView to the code it works as well in BricsCAD in a PointMonitor!
Sorry James that I incorrectly informed you, I was not aware of the brilliant solution!  :mrgreen:
jmaeding
« Reply #7 on: October 03, 2017, 11:07:38 AM »
Huiz, you were right that bricsys is working on it, they told me also.
I also added a #if BCAD...statement to just run for bcad.
The use of transients like this is going to change so many tools I have done.
I used to use grdraw but that is archaic compared to transients.
James Maeding
Atook
  • AKA Tim
« Reply #8 on: October 25, 2017, 11:41:34 PM »
Thanks for the workaround Daniel. Worked a treat here as well.
FYI as of Bricscad V18.1.02 beta, transients are still borked and need the .SetCurrentView call to show up.
« Last Edit: October 25, 2017, 11:46:32 PM by Atook »
Danipon
  • Mosquito
« Reply #9 on: January 01, 2018, 11:38:27 AM »
Just for fun refactored the code to show the UpdateTransient method.
C#-VS2017 Default. Tested in A2018 and B18. Daniel workaround confirmed. Code working in 2D only. Forgive namespace.
Code - C#: [Select]
  1. using System;
  2. using System.Collections.Generic;
  3.
  4.
  5. #if ACAD
  6. using Autodesk.AutoCAD.ApplicationServices;
  7. using Autodesk.AutoCAD.EditorInput;
  8. using Autodesk.AutoCAD.Geometry;
  9. using Autodesk.AutoCAD.GraphicsInterface;
  10. using DbPolyline = Autodesk.AutoCAD.DatabaseServices.Polyline;
  11. #elif BCAD
  12. using Bricscad.ApplicationServices;
  13. using Bricscad.EditorInput;
  14. using Teigha.Geometry;
  15. using Teigha.GraphicsInterface;
  16. using DbPolyline = Teigha.DatabaseServices.Polyline;
  17. #endif
  18.
  19.
  20. namespace TopMecNet.Experimental
  21. {
  22.     public class PointsPicker
  23.     {
  24.         private readonly Editor _editor;
  25.
  26.         private List<Point2d> _pickedPoints;
  27.
  28.         private Point2d _pickedPoint;
  29.
  30.         private DbPolyline _pline;
  31.
  32.         private bool _pointPicked;
  33.
  34.
  35.         public PointsPicker(Document dwg)
  36.         {
  37.             _editor = dwg.Editor;
  38.         }
  39.
  40.         public List<Point2d> PickedPoints
  41.         {
  42.             get { return _pickedPoints; }
  43.         }
  44.
  45.         public void PickPoints()
  46.         {
  47.             _pickedPoints = new List<Point2d>();
  48.
  49.             // get first point
  50.             var opt = new PromptPointOptions("\nPick Point: ");
  51.             var res = _editor.GetPoint(opt);
  52.
  53.             if (res.Status != PromptStatus.OK)
  54.                 return;
  55.
  56.             _pickedPoint = new Point2d(res.Value.X, res.Value.Y);
  57.             PickedPoints.Add(_pickedPoint);
  58.             _pointPicked = true;
  59.
  60.             try
  61.             {
  62.                 CreateTransientGraphics();
  63.
  64.                 // handling mouse cursor moving during picking
  65.                 _editor.PointMonitor += _editor_PointMonitor;
  66.
  67.                 // get more points
  68.                 while (PickNewPoint())
  69.                 {
  70.                     PickedPoints.Add(_pickedPoint);
  71.                     _pointPicked = true;
  72.                 }
  73.
  74.             }
  75.             catch(Exception ex)
  76.             {
  77.                 _editor.WriteMessage(ex.Message);
  78.             }
  79.             finally
  80.             {
  81.                 ClearTransientGraphics();
  82.
  83.                 // remove PointMonitor handler
  84.                 _editor.PointMonitor -= _editor_PointMonitor;
  85.             }
  86.         }
  87.
  88.         private bool PickNewPoint()
  89.         {
  90.             var opt = new PromptPointOptions("\nPick Point: ") {AllowNone = true};
  91.             var res = _editor.GetPoint(opt);
  92.
  93.             if (res.Status != PromptStatus.OK)
  94.                 return false;
  95.
  96.             _pickedPoint = new Point2d(res.Value.X, res.Value.Y);
  97.             return true;
  98.         }
  99.
  100.
  101.         private void CreateTransientGraphics()
  102.         {
  103.             _pline = new DbPolyline(0) {ColorIndex = 1};
  104.
  105.             TransientManager.CurrentTransientManager.AddTransient(
  106.                 _pline, TransientDrawingMode.DirectShortTerm, 128
  107.                 , new IntegerCollection());
  108.         }
  109.
  110.         private void ClearTransientGraphics()
  111.         {
  112.             TransientManager.CurrentTransientManager.EraseTransients(TransientDrawingMode.DirectShortTerm,
  113.                 128, new IntegerCollection());
  114.
  115.             if (_pline != null)
  116.                 _pline.Dispose();
  117.
  118.             _pline = null;
  119.         }
  120.
  121.         private void UpdateTransientGraphics(Point2d dragVertex)
  122.         {
  123.             if (_pointPicked)
  124.             {
  125.                 // add the picked vertex
  126.                 _pline.AddVertexAt(_pline.NumberOfVertices, _pickedPoint, 0.0, 0.0, 0.0);
  127.                 // add the dragging vertex
  128.                 _pline.AddVertexAt(_pline.NumberOfVertices, dragVertex, 0.0, 0.0, 0.0);
  129.             }
  130.             else
  131.             {
  132.                 // update the last vertex
  133.                 _pline.SetPointAt(_pline.NumberOfVertices - 1, dragVertex);
  134.             }
  135.
  136.             TransientManager.CurrentTransientManager.UpdateTransient(_pline, new IntegerCollection());
  137.
  138.             // wake up BricsCAD
  139.             using (var rec = _editor.GetCurrentView())
  140.                 _editor.SetCurrentView(rec);
  141.
  142.             _pointPicked = false;
  143.         }
  144.
  145.
  146.
  147.         private void _editor_PointMonitor(object sender, PointMonitorEventArgs e)
  148.         {
  149.             // simulate next vertex
  150.             UpdateTransientGraphics(new Point2d(e.Context.RawPoint.X, e.Context.RawPoint.Y));
  151.         }
  152.
  153.     }
  154.
  155.     /// <summary>
  156.     /// Class TestPickPoints. ATTACH COMMAND HERE.
  157.     /// </summary>
  158.     public static class TestPickPoints
  159.     {
  160.         public static void Test()
  161.         {
  162.             var dwg = Application.DocumentManager.MdiActiveDocument;
  163.
  164.             var pointsPicker = new PointsPicker(dwg);
  165.             pointsPicker.PickPoints();
  166.             var points = pointsPicker.PickedPoints;
  167.
  168.             Application.DocumentManager.MdiActiveDocument.Editor.WriteMessage(string.Format("Picked {0} points.", points.Count));
  169.         }
  170.     }
  171.
  172. }
  173.
