Author Topic: Architects...  (Read 1221 times)
Rob...
Architects...
« on: September 26, 2017, 01:31:21 PM »
Response from architect after receiving our model, "Could you also send PDFs?"
Me to myself, "Why don't you make them? It's only a handful of sheets. You have everything you need right there in front of you."
SMH...
CAD Tech
Matt__W
  • I like my water diluted.
Re: Architects...
« Reply #1 on: September 26, 2017, 01:55:50 PM »
Next time you send the model, make sure you explode all of the dimensions and blocks. Oh... and put everything on layer 0.
(sounds like they're relatively new to Revit?)
Autodesk Expert Elite
Autodesk Revit Architecture, Structure, MEP Mechanical and MEP Electrical Certified Professional
Building Performance Analysis Certified (BPAC v3.0)
Autodesk Navisworks 2014 Essentials
Re: Architects...
« Reply #2 on: September 26, 2017, 02:02:19 PM »
SMH...
sounds like lazy....and of questionable competence
lamarn
Re: Architects...
« Reply #3 on: September 26, 2017, 02:43:11 PM »
What version of PDF are they using??
dgorsman
Re: Architects...
« Reply #4 on: September 26, 2017, 05:44:32 PM »
Down-loading responsibility: if something is off on the PDF drawing and they didn't create it, guess who's fault it is...
Then again, what does the contract indicate?  Are prepared drawings included or was it just the model?
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
Rob...
Re: Architects...
« Reply #5 on: September 26, 2017, 05:46:14 PM »
This was just an interim model share. Not a submission.
CAD Tech
Krushert
  • FREE BEER Tomorrow!!
Re: Architects...
« Reply #6 on: September 26, 2017, 07:02:42 PM »
I always send PDFs.  It takes all of what 5 to 10 minutes.  Because there is going some who can't access the model.
I + XI = X is true ...
... if you change your perspective.
Daniel J. Ellis
Re: Architects...
« Reply #7 on: September 27, 2017, 03:53:48 AM »
I guess different people need different things, and you generally prefer to receive what you actually need..
I'd bet about 50% of all the email I send are effectively "Thanks for the PDF, can I have it as a DWG as well, please!"
dJE
dJE
hudster
Re: Architects...
« Reply #8 on: September 27, 2017, 03:59:12 AM »
Our Architect just moved the site level up by 500MM, screwing all our levels, when asked why it moved, he "doesn't know, but it need to be there".
Master_Shake
Re: Architects...
« Reply #9 on: September 27, 2017, 08:36:36 AM »
Happens, I have a hunch he was viewing emails on an iPad and couldn't open the revit file.
