Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Continuous selection entity inside block, then select the entity change color
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Continuous selection entity inside block, then select the entity change color (Read 1393 times)
well20152016
Newt
on:
September 23, 2017, 12:02:03 AM »
Code - Auto/Visual Lisp:
[Select]
vl-load-com
defun
c:tt
lst ss
setq
ss
ssadd
while
setq
Ent
nentsel
\n
Pick an entity inside the block: "
setq
lst
cons
ent lst
ss
ssadd
car
ent
ss
sssetfirst
nil
ss
foreach
a lst
vla-put-Color
vlax
ename
vla-object
car
a
6
vla-Regen
vla-get-ActiveDocument
vlax-get-acad-object
:vlax-true
EDIT (John): Added code tags for better display.
Last Edit: September 25, 2017, 09:35:55 AM by John Kaul (Se7en)
Logged
Seagull
London, England
WWW
Re: Continuous selection entity inside block, then select the entity change color
Reply #1 on:
September 23, 2017, 07:22:43 AM »
Is there a question here?
Logged
Lee Mac Programming
Twitter
Exchange App Store
well20152016
Newt
Reply #2 on:
September 23, 2017, 08:59:14 AM »
My lisp, I don't know what's wrong!
Logged
ribarm
Gator
Marko Ribar, architect
WWW
Reply #3 on:
September 23, 2017, 01:02:21 PM »
AFAIK, you can't highlight nested entities... You could though try changing color and transparency...
Something like this :
[Select]
defun
c:tt
adoc ent lst
vl-load-com
setq
adoc
vla-get-activedocument
while
setq
ent
car
nentsel
\n
setq
lst
cons
list
ent
vla
get
entitytransparency
vlax
ename
vla-object
ent
lst
foreach
a lst
vla-put-color
vlax
ename
vla-object
car
a
1
vla
put
entitytransparency
vlax
ename
vla-object
car
a
75
vla-regen
adoc
:vlax-true
foreach
a lst
vla-put-color
vlax
ename
vla-object
car
a
6
vla
put
entitytransparency
vlax
ename
vla-object
car
a
cadr
a
vla-regen
adoc
:vlax-true
princ
Cheers...
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
well20152016
Newt
Reply #4 on:
September 23, 2017, 07:14:33 PM »
Thank you, ribarm, Lee, Mac!
I wonder if it can be implemented with ssget?
Logged
Seagull
London, England
WWW
Reply #5 on:
September 23, 2017, 07:32:09 PM »
Quote from: well20152016 on September 23, 2017, 07:14:33 PM
I recall that Tim tried this a long time ago - see
here
Logged
Lee Mac Programming
Twitter
Exchange App Store
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
