Author Topic: Volume of a 3D solid  (Read 4399 times)
Fuccaro
« on: May 27, 2005, 06:17:42 AM »
I try to write a routine that returns the mass of a solid. It sounds simple. I know the density but how do I get the volume?
Please be gentle with me, I work in AutoLisp only.
Thank you!
« Reply #1 on: May 27, 2005, 07:26:01 AM »
Perhaps --
(defun c:SumVolume ( / getvolume volume ss i )
    (defun getvolume ( object / area )
        (vl-catch-all-apply
           '(lambda ()
                (setq volume
                    (vla-get-volume
                        object
        (if volume volume 0.0)
    (if (setq volume 0.0 ss (ssget))
        (repeat (setq i (sslength ss))
            (setq volume
                (+ volume
                    (getvolume
                        (vlax-ename->vla-object
                            (ssname ss
                                (setq i (1- i))
Jürg Menzi
  • Oberegg, Switzerland
« Reply #2 on: May 27, 2005, 07:51:13 AM »
Hi
Visit my homepage -> Free Stuff and search for 'VxGetMassProps'
Cheers
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
CADaver
« Reply #3 on: May 27, 2005, 09:09:44 AM »
or maybe:
(defun c:solvol ()
  (setq a 0 volume 0
        ss (ssget '((0 . "3dsolid"))
  (if ss
      (setq n (1- (sslength ss)))
      (while (>= n 0)
(setq solidobj (vlax-ename->vla-object (ssname ss n)))
       (if (= (vla-get-objectName solidobj) "AcDb3dSolid")
               (setq volume (vla-get-volume solidobj))
        (setq a (+ a volume)
              n (1- n))
      ) ;;close while
     );;close progn
    (alert "\nNo Solids selected!")
) ;;close if
(princ (strcat "\nSolid volume  =  " (rtos a 2 6) "  Cu.In."))
(princ (strcat "\nSolid volume  =  " (rtos (/ a 1728.0) 2 4) "  Cu.Ft."))
(princ (strcat "\nSolid volume  =  " (rtos (/ a 46656.0) 2 2) "  Cu.Yd."))
DEVITG
only autolisp
« Reply #4 on: May 27, 2005, 09:38:36 PM »
Seem to be Fucaro use autolisp , and no visualisp
massprop will give you the volumen and mass
It ask you to save to a file , then you have to retrieve ti from such file
This is the result of massprop of a cube 1 unit side drawn at 0 0 0
Command: _massprop
Select objects: 1 found
Select objects:
 ----------------   SOLIDS    ----------------
Mass:                    1.0000
Volume:                  1.0000
Bounding box:         X: 0.0000  --  1.0000
                      Y: 0.0000  --  1.0000
                      Z: 0.0000  --  1.0000
Centroid:             X: 0.5000
                      Y: 0.5000
                      Z: 0.5000
Moments of inertia:   X: 0.6667
                      Y: 0.6667
                      Z: 0.6667
Products of inertia: XY: 0.2500
                     YZ: 0.2500
                     ZX: 0.2500
Radii of gyration:    X: 0.8165
                      Y: 0.8165
                      Z: 0.8165
Principal moments and X-Y-Z directions about centroid:
                      I: 0.1667 along [1.0000 0.0000 0.0000]
                      J: 0.1667 along [0.0000 1.0000 0.0000]
                      K: 0.1667 along [0.0000 0.0000 1.0000]
Press ENTER to continue:
Write analysis to a file? [Yes/No] <N>: y
This is what the such file contents
    Mass:                    1.0000
    Volume:                  1.0000
                          Y: 0.0000  --  1.0000
                          Z: 0.0000  --  1.0000
    Centroid:             X: 0.5000
                          Y: 0.5000
                          Z: 0.5000
                          Y: 0.6667
                          Z: 0.6667
                         YZ: 0.2500
                         ZX: 0.2500
                          Y: 0.8165
                          Z: 0.8165
                          J: 0.1667 along
[/list:u]
Fuccaro
« Reply #5 on: May 30, 2005, 02:32:16 AM »
DEVITG
I should use the (command ...) function to save the properties into a file, open that file and search for the volume... It is a too long way.
Your routine worked just perfect. I operated some minor changes. When I select a solid the text window will pop up showing me the mass for the materials I mostlu use: cooper, steel, aluminium.
AutoLisp and VL code can be mixed; lucky me :) !
CADaver
I will try your way too
Jürg Menzi
I could download the code but probable I will not be able to make changes.
thanks alot for all your replies!
Jürg Menzi
« Reply #6 on: May 30, 2005, 10:20:55 AM »
Ok, see:
http://www.theswamp.org/lilly_pond/juergmenzi/GetMassProps.lsp?nossi=1
You've to add the density formulas only.
Cheers
