Author Topic: Freezing Layer in Layouts  (Read 2456 times)
RoSiNiNo
  • Mosquito
« on: September 12, 2017, 07:00:12 AM »
I'm trying to freeze the layer of a selected item in every other viewport of every layouts.
This code seems to work in the active layout but not in all other layouts.
Any ideas?
How do I get only the viewports in the layout and not the layout itself?
using Autodesk.AutoCAD.Colors;
[assembly: CommandClass(typeof(RSNNGrundbeanspruchung.Commands))]
namespace RSNNGrundbeanspruchung
    public class Commands
        [CommandMethod("AFLayerfrierenTest")]
        public static void AFFrierenTest()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var db = HostApplicationServices.WorkingDatabase;
            var ed = doc.Editor;
            PromptEntityOptions peo = new PromptEntityOptions("\nObjekt zeigen: ");
            peo.SetRejectMessage("\nKein gültiges Objekt gewählt. Objekt zeigen: ");
            peo.AddAllowedClass(typeof(Entity), false);
            do
                PromptEntityResult per = ed.GetEntity(peo);
                if (per.Status != PromptStatus.OK)
                    return;
                ObjectId objId = per.ObjectId;
                using (var tr = db.TransactionManager.StartTransaction())
                    Entity ent = (Entity)tr.GetObject(objId, OpenMode.ForRead);
                    LayerTable Layers = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
                    LayerTableRecord Layer = (LayerTableRecord)tr.GetObject(ent.LayerId, OpenMode.ForWrite);
                    peo.Message = string.Format("\nLayer: \"{0}\" wird in anderen Fenstern ausgeschaltet.\nObjekt zeigen: ", Layer.Name);
                    // Freeze "Test" layer in all viewports
                    ObjectId[] ids = new ObjectId[1] { ent.LayerId };
                    DBDictionary layoutDict = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
                    foreach (DBDictionaryEntry entry in layoutDict)
                        if (entry.Key != "Model")
                            Layout lay = (Layout)tr.GetObject(entry.Value, OpenMode.ForRead);
                            foreach (ObjectId vpId in lay.GetViewports())
                                Viewport vp = (Viewport)tr.GetObject(vpId, OpenMode.ForWrite);
                                if (ed.CurrentViewportObjectId != vpId)
                                    vp.FreezeLayersInViewport(ids.GetEnumerator());
                   tr.Commit();
            } while (true);
RoSiNiNo
  • Mosquito
Re: Freezing Layer in Layouts
« Reply #1 on: September 12, 2017, 07:22:43 AM »
OK, I've found the solution to both questions.
You have to use Database.GetViewports(false).
        [CommandMethod("AFLayerfrierenTest2")]
        public static void AFFrierenTest2()
            do
                    return;
                    ObjectIdCollection layerIds = new ObjectIdCollection();
                    layerIds.Add(ent.LayerId);
                    foreach (ObjectId vpId in db.GetViewports(false))
                            vp.FreezeLayersInViewport(layerIds.GetEnumerator());
                    tr.Commit();
            } while (true);
RoSiNiNo
  • Mosquito
« Reply #2 on: September 12, 2017, 07:33:32 AM »
OK, this one doesn't work, too.
I just tried one layer in the first layout and switched to the next and it seemed to work, but then I tried it again in another viewport and it didn't work.
RoSiNiNo
  • Mosquito
« Reply #3 on: September 13, 2017, 01:13:37 AM »
After a little bit of testing I can see that only the first time I use this command it works fine. Then it does not work anymore.
Also if I change the layout before the first use, it does not work.
gile
  • Marseille, France
« Reply #4 on: September 13, 2017, 06:34:47 AM »
This seems to work for me:
Code - C#: [Select]
  1. using Autodesk.AutoCAD.ApplicationServices;
  2. using Autodesk.AutoCAD.DatabaseServices;
  3. using Autodesk.AutoCAD.EditorInput;
  4. using Autodesk.AutoCAD.Runtime;
  5.
  6. [assembly: CommandClass(typeof(VpFreezeBySelection.Commands))]
  7.
  8. namespace VpFreezeBySelection
  9. {
  10.     public class Commands
  11.     {
  12.         [CommandMethod("TEST", CommandFlags.NoTileMode | CommandFlags.NoPaperSpace)]
  13.         public void Test()
  14.         {
  15.             var doc = Application.DocumentManager.MdiActiveDocument;
  16.             var db = doc.Database;
  17.             var ed = doc.Editor;
  18.
  19.             var per = ed.GetEntity("\nSelect an entity: ");
  20.             if (per.Status != PromptStatus.OK)
  21.                 return;
  22.
  23.             using (var tr = db.TransactionManager.StartTransaction())
  24.             {
  25.                 var lt = (LayerTable)tr.GetObject(db.LayerTableId, OpenMode.ForRead);
  26.                 var ent = (Entity)tr.GetObject(per.ObjectId, OpenMode.ForRead);
  27.                 var ids = new[] { lt[ent.Layer] };
  28.                 var dic = (DBDictionary)tr.GetObject(db.LayoutDictionaryId, OpenMode.ForRead);
  29.                 foreach (DBDictionaryEntry entry in dic)
  30.                 {
  31.                     if (entry.Key == "Model")
  32.                         continue;
  33.                     var layout = (Layout)tr.GetObject(entry.Value, OpenMode.ForRead);
  34.                     foreach (ObjectId id in layout.GetViewports())
  35.                     {
  36.                         if (id != ed.CurrentViewportObjectId)
  37.                         {
  38.                             var vp = (Viewport)tr.GetObject(id, OpenMode.ForWrite);
  39.                             vp.FreezeLayersInViewport(ids.GetEnumerator());
  40.                         }
  41.                     }
  42.                 }
  43.                 tr.Commit();
  44.             }
  45.         }
  46.     }
  47. }
  48.
