Author Topic: Add string to predefined List  (Read 1649 times)
vincent.r
« on: September 05, 2017, 02:36:54 AM »
I am newbie to autolisp, I am trying to add a string "MVTTPL-101-DB-11_1" to a predefined list i.e. (setq shrirfi '(fnames)).
I have googled this but could not get solution ? Can anybody help ?
Marc'Antonio Alessi
  • Marco
Re: Add string to predefined List
« Reply #1 on: September 05, 2017, 03:05:41 AM »
What is fnames? string, list, ...?
vincent.r
« Reply #2 on: September 05, 2017, 03:24:44 AM »
its a string in a list. want to some more strings next to fnames.
vincent.r
« Reply #3 on: September 05, 2017, 03:26:24 AM »
my mistake. actually it is (setq shrirfi '("fnames")).
Marc'Antonio Alessi
  • Marco
« Reply #4 on: September 05, 2017, 04:09:09 AM »
Maybe:
Comando: (setq shrirfi '("fnames"))
("fnames")
Comando: (setq shrirfi (cons "MVTTPL-101-DB-11_1" shrirfi))
("MVTTPL-101-DB-11_1" "fnames")
Comando: !shrirfi
vincent.r
« Reply #5 on: September 05, 2017, 04:38:45 AM »
It works great. Thanks Marc'Antonio Alessi. I was trying with append function, now I will use reverse.
Thanks again for your quick reply.
« Reply #7 on: September 05, 2017, 11:28:06 AM »
If you don't want to reverse your list just use append as you mentioned: (append shrirfi '("MVTTPL-101-DB-11_1"))
