Author Topic: Convert coordinate files to x,y  (Read 6338 times)
Re: Convert coordinate files to x,y
« Reply #15 on: August 30, 2017, 03:08:19 PM »
Quick & Dirty concept code.
(defun _TSV->List ( tsvfilename / foo i handle s result )
    (defun foo ( s / result )
        (while (setq i (vl-string-position 9 s nil t))
            (setq
                result (cons (substr s (+ 2 i)) result)
                s      (substr s 1 i)
        (cons s result)
    (if (setq handle (open tsvfilename "r"))
            (while (setq s (read-line handle))
                (setq result (cons (foo s) result))
            (close handle)
            (vl-remove 'nil (reverse result))
(defun _List->CSV ( lst tsvfilename / handle )
    (if (setq handle (open tsvfilename "w"))
            (foreach r lst
                (princ (car r) handle)
                (foreach x (cdr r) (princ "," handle) (princ x handle))
                (princ "\n" handle)
            (null (close handle))
;;  read it in
(setq lst (_TSV->List "c:\\docs\\tsv.txt"))
;;  abuse it
(setq alt (mapcar (function (lambda (r) (reverse (mapcar 'set '(x y) (cdr r))))) lst))
;;  write it out
(_List->CSV alt "c:\\docs\\csv_abused.txt")
;;   orig
0    318349.74    4231547.73
1    318445.61    4231568.79
2    318446.37    4231561.59
3    318443.36    4231549.82
4    318438.82    4231539.87
5    318428.56    4231532.33
;;   abused
4231547.73,318349.74
4231568.79,318445.61
4231561.59,318446.37
4231549.82,318443.36
4231539.87,318438.82
/2¢
VovKa
  • Ukraine
« Reply #16 on: August 30, 2017, 03:30:22 PM »
no foo
(setq result (cons (read (strcat "(" s ")")) result))
« Reply #17 on: August 30, 2017, 05:01:27 PM »
If the data hosts non numerical items that technique would (undesirably) yield symbols instead of strings.
Cheers.
fools
  • China
« Reply #18 on: August 30, 2017, 06:57:20 PM »
I attach a *.txt file with the coordinates.I try fools code but the *.pl file is empty
My code is written very rough, just to show the way.
Change space to tab in function F_Str2Lst can convert correctly.
  1. (DEFUN c:test (/ FF FFN TXT TXTS)
  2.   (SETQ ffn  (GETFILED "Select file" "" "txt" 0)
  3.         ff   (OPEN ffn "r")
  4.         txts nil
  5.   )
  6.   (WHILE (SETQ txt (READ-LINE ff)) (SETQ txts (CONS txt txts)))
  7.   (CLOSE ff)
  8.   ;;(VL-FILE-RENAME ffn (STRCAT (SUBSTR ffn 1 (- (STRLEN ffn) 3)) "bak"))
  9.   (SETQ txts (MAPCAR 'CDR (MAPCAR 'F_Str2Lst (MAPCAR 'F_NoExtraSpaces (REVERSE txts)))))
  10.   (SETQ ff (OPEN (STRCAT (SUBSTR ffn 1 (- (STRLEN ffn) 3)) "pl") "w"))
  11.   (FOREACH item txts (WRITE-LINE (STRCAT (CAR item) "," (CADR item)) ff))
  12.   (CLOSE ff)
  13. )
  14.
  15. (DEFUN F_NoExtraSpaces (str / pos)
  16.   (SETQ str (VL-STRING-TRIM " " str))
  17.   (WHILE (SETQ pos (VL-STRING-SEARCH "  " str pos)) (SETQ str (VL-STRING-SUBST " " "  " str pos)))
  18.   str
  19. )
  20.
  21. (DEFUN F_Str2Lst (str / pos)
  22.   (IF (SETQ pos (VL-STRING-SEARCH "\t" str))
  23.     (CONS (SUBSTR str 1 pos) (F_Str2Lst (SUBSTR str (+ (STRLEN "\t") pos 1))))
  24.     (LIST str)
  25.   )
  26. )
Good good study , day day up . Sorry about my Chinglish .
pedroantonio
« Reply #19 on: August 30, 2017, 07:08:35 PM »
Thank you   :smitten: :smitten:
fools
  • China
« Reply #20 on: August 30, 2017, 07:10:47 PM »
no foo
Using read function maybe change data.
(SETQ str " 0   318349.74  4231547.73 ")
(read (strcat "(" str ")"))
result:
(0 318350.0 4.23155e+006)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #21 on: August 30, 2017, 11:53:10 PM »
hI. I am searching for a lisp to convert coordinate files files to x,y  (*.txt)
1) p,x,y,z --->x,y
2) p,x,y ---->x,y
3) p x y z ---> x,y
4) p x y ----> x,y
i know that i can do it with excel but i need something faster.
to be more in line with the original requirements the translators would need to work successfully on this list.
with the addition of TABS as per the provided file.
0   300000.00   4000000.00 0.0
2 318446.37,4231561.59,123
3   318443.36,4231549.82
4   318438.82      4231539.87    0.0
5   318428.56,   4231532.33,      0.0
6,318425.25,4231523.57,0.0
7,   318428.55,   4231513.05,   0.0
8   318442.57   4231516.64
9   318455.87   4231506.94
10   318473.12   4231495.81
just saying ...
Called Kerry in my other life
I live at UTC + 13.00
fools
  • China
« Reply #22 on: August 31, 2017, 01:20:40 AM »
Thanks for remind. I change a function to increase versatility.
  1. (defun c:test (/ FF FFN TXT TXTS)
  2.   (setq ffn  (getfiled "Select file" "" "txt" 0)
  3.         ff   (open ffn "r")
  4.         txts nil
  5.   )
  6.   (while (setq txt (read-line ff)) (setq txts (cons txt txts)))
  7.   (close ff)
  8.   (setq txts (mapcar '(lambda (x) (STD-STRSPLIT x "\t,; ")) (reverse txts)))
  9.   (setq txts
  10.          (mapcar
  11.            '(lambda (x) (vl-remove-if '(lambda (y) (and (not (equal "0" y)) (zerop (atof y)))) x))
  12.            txts
  13.          )
  14.   )
  15.   (setq ff (open (strcat (substr ffn 1 (- (strlen ffn) 3)) "pl") "w"))
  16.   (foreach item txts (write-line (strcat (cadr item) "," (caddr item)) ff))
  17.   (close ff)
  18.   (princ)
  19. )
  20.
  21. ;;; The order of chars in delim is not important.
  22. ;;; keeping null tokens, not as with std-strtok.
  23. ;;; Might be renamed to std-string-split
  24. ;;; by Vladimir Nesterowsky
  25. (defun STD-STRSPLIT (s delims / len s1 i c lst)
  26.   (setq delims (vl-string->list delims) ; fixed
  27.         len    (strlen s)
  28.         s1     ""
  29.         i      (1+ len)
  30.   )
  31.   (while (> (setq i (1- i)) 0)
  32.     (setq c (substr s i 1))
  33.     (if (member (ascii c) delims)
  34.       (if (/= i len)                    ; "1,2," -> ("1" "2") and not ("1" "2" "")
  35.         (setq lst (cons s1 lst)
  36.               s1  ""
  37.         )
  38.       )
  39.       (setq s1 (strcat c s1))
  40.     )
  41.   )
  42.   (cons s1 lst)                         ; ",1,2" -> ("" "1" "2")
  43. )
1.txt
1.pl
300000.00,4000000.00
318445.61,4231568.79
318438.82,4231539.87
318428.56,4231532.33
318428.55,4231513.05
318442.57,4231516.64
318455.87,4231506.94
318473.12,4231495.81
anhquang1989
« Reply #23 on: August 31, 2017, 02:14:16 AM »
This is the norm of my work. It may be right for you. please try
Import txt file, csv with the format: P Y Y Z Code
- different separators like comma, space, tab
- Still works well with other formats like
+ P X Y
+ P X Y Z
+ P Y X
+ P Y X Z
« Reply #24 on: August 31, 2017, 10:53:24 AM »
just saying ...
Eschewing the important but I don't have time for "importance of well formed data" discussion I'll ante up this 2 minute quickie:
(defun _Normalize ( str )
    (foreach delim '(" " "," "\t")
        (foreach pattern (list (strcat " " delim) (strcat delim " "))
            (while (vl-string-search pattern str)
                (setq str (vl-string-subst delim pattern str))
    (vl-string-translate " \t" ",," str)
    (foreach test
            "0   300000.00   4000000.00 0.0"
            "1   318445.61   4231568.79"
            "2 318446.37,4231561.59,123"
            "3   318443.36,4231549.82"
            "4   318438.82      4231539.87    0.0"
            "5   318428.56,   4231532.33,      0.0"
            "6,318425.25,4231523.57,0.0"
            "7,   318428.55,   4231513.05,   0.0"
            "8 \t  318442.57   4231516.64"
            "9   318455.87 \t  4231506.94"
            "10   318473.12   4231495.81"
        (princ (strcat "\n" test " >> " (_Normalize test)))
0   300000.00   4000000.00 0.0        >> 0,300000.00,4000000.00,0.0
1   318445.61   4231568.79            >> 1,318445.61,4231568.79
2 318446.37,4231561.59,123            >> 2,318446.37,4231561.59,123
3   318443.36,4231549.82              >> 3,318443.36,4231549.82
4   318438.82      4231539.87    0.0  >> 4,318438.82,4231539.87,0.0
5   318428.56,   4231532.33,      0.0 >> 5,318428.56,4231532.33,0.0
6,318425.25,4231523.57,0.0            >> 6,318425.25,4231523.57,0.0
7,   318428.55,   4231513.05,   0.0   >> 7,318428.55,4231513.05,0.0
8   318442.57   4231516.64            >> 8,318442.57,4231516.64
9   318455.87    4231506.94           >> 9,318455.87,4231506.94
10   318473.12   4231495.81           >> 10,318473.12,4231495.81
Cheers.
« Reply #25 on: August 31, 2017, 01:36:25 PM »
Just to offer an alternative approach:
  1. (defun NormaliseList ( src dst lst / rgx rtn )
  2.     (if (setq rgx (vlax-create-object "vbscript.regexp"))
  3.         (progn
  4.             (vl-catch-all-apply
  5.                '(lambda nil
  6.                     (vlax-put-property rgx 'global actrue)
  7.                     (vlax-put-property rgx 'pattern src)
  8.                     (setq rtn (mapcar '(lambda ( x ) (vlax-invoke rgx 'replace x dst)) lst))
  9.                 )
  10.             )
  11.             (vlax-release-object rgx)
  12.             rtn
  13.         )
  14.     )
  15. )
  1.     (NormaliseList
  2.         "[^\\s\\,]+[\\s\\,]+([^\\s\\,]+)[\\s\\,]+([^\\s\\,]+).*"
  3.         "$1,$2"
  4.        '(
  5.             "0   300000.00   4000000.00 0.0"
  6.             "1   318445.61   4231568.79"
  7.             "2 318446.37,4231561.59,123"
  8.             "3   318443.36,4231549.82"
  9.             "4   318438.82      4231539.87    0.0"
  10.             "5   318428.56,   4231532.33,      0.0"
  11.             "6,318425.25,4231523.57,0.0"
  12.             "7,   318428.55,   4231513.05,   0.0"
  13.             "8 \t  318442.57   4231516.64"
  14.             "9   318455.87 \t  4231506.94"
  15.             "10   318473.12   4231495.81"
  16.         )
  17.     )
  18. )
Yields:
"300000.00,4000000.00"
"318445.61,4231568.79"
"318446.37,4231561.59"
"318443.36,4231549.82"
"318438.82,4231539.87"
"318428.56,4231532.33"
"318425.25,4231523.57"
"318428.55,4231513.05"
"318442.57,4231516.64"
"318455.87,4231506.94"
"318473.12,4231495.81"
« Reply #26 on: August 31, 2017, 02:39:54 PM »
Nicely done Lee, cheers.
« Reply #27 on: August 31, 2017, 05:42:42 PM »
Cheers Michael, same to you. :-)
fools
  • China
« Reply #28 on: September 01, 2017, 09:39:54 PM »
Thanks Lee and MP, I learned a lot.
DEVITG
« Reply #29 on: September 02, 2017, 12:38:32 AM »
Just put , or upload, or whats ever, your sample dwg and your sample xyz value file, as you do it by hand.
Keep it simple sir .. just KISS
