Author Topic: Convert coordinate files to x,y  (Read 6348 times)
pedroantonio
« on: August 30, 2017, 04:15:27 AM »
hI. I am searching for a lisp to convert coordinate files files to x,y  (*.txt)
1) p,x,y,z --->x,y
2) p,x,y ---->x,y
3) p x y z ---> x,y
4) p x y ----> x,y
i know that i can do it with excel but i need something faster.
pedroantonio
Re: Convert coordinate files to x,y
« Reply #1 on: August 30, 2017, 05:41:52 AM »
any ideas ?
Pad
« Reply #2 on: August 30, 2017, 07:14:24 AM »
you could try this
http://www.lancaster.ac.uk/~steveb/cpaap/pfe/default.htm
and make yourself a macro for each variation.
« Reply #3 on: August 30, 2017, 08:04:44 AM »
pedroantonio
« Reply #4 on: August 30, 2017, 10:22:22 AM »
i can not understand it can you give me an example for    p x y ----> x,y  ?
thanks
pedroantonio
« Reply #5 on: August 30, 2017, 11:10:41 AM »
i am thinking something like this
  1. (defun c:test (/ )
  2.
  3.   (setq title "select file"
  4.         fname (getfiled title path "txt" 0)
  5.         path  (if (setq tmp (vl-filename-directory fname))
  6.                 (strcat tmp "\\")
  7.                 ""
  8.               )
  9.   (setq f (open (strcat path
  10.                         ""
  11.                         (vl-filename-base fname)
  12.                         ".pl"
  13.                 )
  14.                 "w"
  15.           )
  16.
  17.     (write-line (strcat (rtos (cadr i) 2 3)
  18.                         ","
  19.                          (rtos (caddr i) 2 3)
  20.
  21.
  22.                 )
  23.                 f
  24.     )
  25.   )
  26. )
  27.  )
  28.
  29.
but is not working. Any ideas?
« Reply #6 on: August 30, 2017, 11:16:27 AM »
can you post a sample of the  " coordinate files files"  to x,y you are starting with?
And what you want them to look like when done?
It might be possible to use QGIS or similar to do this.
« Reply #7 on: August 30, 2017, 11:24:27 AM »
something like this
gawk "{print $2 $3 }" input-file.txt > output-file.txt
« Reply #8 on: August 30, 2017, 11:38:13 AM »
It would actually be ...
gawk "{print $2\",\" $3 }" data.txt > outputfile.txt
Its all in that link i posted earlier.
fools
  • China
« Reply #9 on: August 30, 2017, 11:39:34 AM »
thanks
  1. (DEFUN c:test (/ FF FFN TXT TXTS)
  2.   (SETQ ffn  (GETFILED "Select file" "" "txt" 0)
  3.         ff   (OPEN ffn "r")
  4.         txts nil
  5.   )
  6.   (WHILE (SETQ txt (READ-LINE ff)) (SETQ txts (CONS txt txts)))
  7.   (CLOSE ff)
  8.   ;;(VL-FILE-RENAME ffn (STRCAT (SUBSTR ffn 1 (- (STRLEN ffn) 3)) "bak"))
  9.   (SETQ txts (MAPCAR 'CDR (MAPCAR 'F_Str2Lst (MAPCAR 'F_NoExtraSpaces (REVERSE txts)))))
  10.   (SETQ ff (OPEN (STRCAT (SUBSTR ffn 1 (- (STRLEN ffn) 3)) "pl") "w"))
  11.   (FOREACH item txts (WRITE-LINE (STRCAT (CAR item) "," (CADR item)) ff))
  12.   (CLOSE ff)
  13. )
  14.
  15. (DEFUN F_NoExtraSpaces (str / pos)
  16.   (SETQ str (VL-STRING-TRIM " " str))
  17.   (WHILE (SETQ pos (VL-STRING-SEARCH "  " str pos)) (SETQ str (VL-STRING-SUBST " " "  " str pos)))
  18.   str
  19. )
  20.
  21. (DEFUN F_Str2Lst (str / pos)
  22.   (IF (SETQ pos (VL-STRING-SEARCH " " str))
  23.     (CONS (SUBSTR str 1 pos) (F_Str2Lst (SUBSTR str (+ (STRLEN " ") pos 1))))
  24.     (LIST str)
  25.   )
  26. )
Good good study , day day up . Sorry about my Chinglish .
pedroantonio
« Reply #10 on: August 30, 2017, 12:47:38 PM »
I attach a *.txt file with the coordinates.I try fools code but the *.pl file is empty
pedroantonio
« Reply #11 on: August 30, 2017, 12:58:33 PM »
i want the export file to be like this
318349.74,4231547.73
318445.61,4231568.79
318446.37,4231561.59
318443.36,4231549.82
318438.82,4231539.87
318428.56,4231532.33
318425.25,4231523.57
318428.55,4231513.05
318442.57,4231516.64
318455.87,4231506.94
318473.12,4231495.81
318473.84,4231490.78
318468.81,4231486.11
318468.45,4231473.18
318464.85,4231451.63
318460.90,4231446.96
318447.24,4231446.60
318439.70,4231458.45
318431.79,4231475.34
318424.60,4231475.34
318399.26,4231473.08
318390.21,4231473.39
318382.97,4231477.91
318379.64,4231487.26
318376.02,4231521.35
318372.99,4231537.20
318368.15,4231541.13
318354.88,4231545.65
thanks
« Reply #12 on: August 30, 2017, 01:24:44 PM »
You're not even trying are you?
gawk "{print $2\",\" $3 }" 1.txt
pedroantonio
« Reply #13 on: August 30, 2017, 01:35:49 PM »
Mark i am not using scripts.I use only lisp codes
« Reply #14 on: August 30, 2017, 02:37:32 PM »
yes you could read that file into QGIS (its free GIS software)
new layer from delimited file...
have it read your desired columns from that file
then export it as comma delimited file or shp file...or lots of formats.
no list/code/ or scripts required
