Author Topic: AutoCAD Viewport Rotate Error  (Read 3075 times)
mailmaverick
« on: August 28, 2017, 04:09:00 AM »
Please see attached drawing. I have a Viewport in 'Layout' TAB which when I rotate by 90 degrees, it changes its extents.
My VPROTATEASSOC variable is set to 1.
tombu
  • ByLayer=>Not0
Re: AutoCAD Viewport Rotate Error
« Reply #1 on: August 28, 2017, 07:55:33 AM »
What commands are you using to rotate it with?  Dview TWist rotates the view, while other methods affect UCS.  What's your UCSFOLLOW set to?
Tom Beauford P.S.M.
Crank
« Reply #2 on: August 28, 2017, 12:33:31 PM »
I see the same.
In Acad2017 it doesn't happen, so I'll guess this is a bug that's new in 2018.1.
But the size of your viewport is only 0.088 x 0.038 drawing units. After rotation the new viewport is 0.1x0.1 drawing units. That's still very very small.
Larger (normal) viewports don't have this problem.
mailmaverick
« Reply #3 on: August 29, 2017, 06:18:36 AM »
I am using ROTATE command to rotate it.
mailmaverick
Re: AutoCAD Viewport Rotate Error (Bug in AutoCAD)
« Reply #4 on: August 31, 2017, 12:46:19 PM »
Still no idea why I'm facing this problem
Crank
« Reply #5 on: August 31, 2017, 01:04:39 PM »
In Acad2018.1 they have added extra options to viewports.
As a result of this the minimum size of a viewport after rotation appears to be 0.1x0.1 drawing units.
Normally this shouldn't be a problem, because your layout is much larger.
I wonder why this is important for you, because such a tiny viewport will look like a dot on your sheet.
tombu
  • ByLayer=>Not0
« Reply #6 on: September 01, 2017, 10:20:20 AM »
Only way I could reproduce your issue was to set VPROTATEASSOC to 0.  With VPROTATEASSOC set to 1 (default) ROTATE works fine.
Tom Beauford P.S.M.
mailmaverick
« Reply #7 on: September 14, 2017, 10:33:34 AM »
Another bug which i have found in AutoCAD 2014 is that when I rotate the viewport using (command "ROTATE" .........) automatically a closed polyline with coordinates same as of Viewport gets created which itself binds with the viewport entity. Anybody else came across such problem ?
Crank
« Reply #8 on: September 16, 2017, 03:49:09 AM »
That's not a bug, it's how it works:
If you look at the dxf-codes, you'll notice that an angle of the viewport isn't present (a viewport is allways orthogonal, but you can rotate/twist the view).
A rotated viewport is clipped from an object (polyline/circle/elipse/region) and has a twisted view. In this case the polyline is automaticly generated.
mailmaverick
« Reply #9 on: September 18, 2017, 04:29:39 AM »
Thanks for your answer Crank. One more thing, if a viewport is rotated, its properties window does not show its rotation. So how to know whether a viewport has been rotated or not ?
ahsattarian
« Reply #10 on: August 11, 2021, 07:07:12 AM »
  1. (setq s (ssname (ssget ":e:s" '((0 . "viewport"))) 0))
  2. (cdr (assoc 51 (entget s)))
PM
« Reply #11 on: August 17, 2021, 05:06:11 PM »
I use this code to rotate viewport. I dont know if it is what are you looking for
  1. ; DVA.LSP
  2.
  3. ; Jim Nakazawa
  4. ; (415) 768-1234
  5.
  6. ; TO SET DVIEW TWIST ANGLE BY POINTING TO AN EXISTING LINE
  7. ; FIRST DRAW THE LINE FROM LEFT TO RIGHT THAT YOU WANT TO SET THE DVIEW
  8. ; TWIST ANGLE FROM
  9.
  10. (defun C:DVA (/ rgm a b pt1 pt2 ang1 )
  11.   (setq rgm (getvar "regenmode"))
  12.   (command "setvar" "regenmode" 0)
  13.   (setq a (entsel "select a line to DVIEW TWist angle: "))
  14.   (setq b (entget (car a)))
  15.   (setq pt1 (cdr (assoc 10 b)))
  16.   (setq pt2 (cdr (assoc 11 b)))
  17.   (setq ang1 (angle pt1 pt2))
  18.   (setq ang1 (/ (* ang1 200.0) pi))
  19.   (setq ang1 (- ang1))
  20.   (command "dview"  "" "tw" ang1 "")
  21.   (command "setvar" "regenmode" rgm)
  22.   (princ "Dview Twist Angle Set to ") (princ (+ 400.0 ang1)) (terpri)
  23. ;this should be modified to show angle in current angular units
  24.   (princ)
  25. ) ;this routine seems to work
  26.
