Author Topic: Zoom Extend All Layouts in All Open Drawings?  (Read 26505 times)
PKENEWELL
Re: Zoom Extend All Layouts in All Open Drawings?
« Reply #45 on: September 07, 2017, 12:55:53 PM »
Perhaps:
Sub ZoomExtentsInAllDocs()
    Dim doc     As AcadDocument, _
        restore As AcadDocument
    Set restore = Application.ActiveDocument
    For Each doc In Documents
        doc.Activate
        Call ZoomExtentsInAllLayouts
    Next
    restore.Activate
End Sub
That did It! Now works as expected. Thanks! LOL - I don't even know if the OP is paying attention anymore.  :-D
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
MSTG007
« Reply #46 on: September 07, 2017, 01:00:42 PM »
I think this is great! Think of all the things you can do now you have this piece of the code squared away.
User has a bunch of drawings open: (They may want to:) i.e.
zoom extents in all layout tabs and save
purge all the opened drawings
possibly perform page setups
Again this is me, brain storming around. All in all. pretty cool.
Civil3D 2020
Grrr1337
« Reply #47 on: September 07, 2017, 05:25:40 PM »
Good job MP,
fluent on several languages, sadly only the computer completely understands what you said (wrote)! :lol:
That said -- I could read in the binary stream from the dvb file I created via my _ReadStream function -- store the data in lisp format -- write out to a dvb file via my _WriteStream function -- then invoke per previous posed code -- ha.
That sounds intriguing!  :-o
But (as a VBA newbie) it makes me wonder are there any advantages in Visual Basic, in order to the functionality, over LISP?
Like I was going thru some VBA tutorials and I saw how much easier is to create dialogs (forms), access objects with properties'n'methods (esp the scripting objects) - but the same could be achieved with pure LISP (although very hard, but still doable).
So is there anything that can be done in VBA and not in LISP? (finally found a VBA'n'LISP guy to ask!)
(apply ''((a b c)(a b c))
vevo.bg
« Reply #48 on: September 07, 2017, 08:09:13 PM »
Good job MP
Merci. :)
... sadly only the computer completely understands what you said (wrote)! :lol:
So very not true, lol.
...are there any advantages in Visual Basic, in order to the functionality, over LISP?
Well there's the ability to iterate over all drawings open in the editor and perform a zoom extents on every layout. :-P
Sorry, couldn't resist -- way tired and not capable of much more than humor at present.
Marc'Antonio Alessi
  • Marco
« Reply #49 on: September 08, 2017, 11:01:32 AM »
... Using vbastmt on 64 bit might I have this problem?
https://www.theswamp.org/index.php?topic=43869.msg491387#msg491387
I'm running 2015 64 bit. Speedy here -- acknowledging one test environment does not make conclusive. Thanks for the heads up. PS -- there's more than one way to skin this cat ... to load code into vbe ... or ... :evil:
Brutal test on old PC with A2017+VBA:
(defun BenchVBA (Times)
  (setvar 'CMDECHO 0)
  (setq #BS (getvar "Millisecs"))
  (repeat Times (command "_.POINT" "_NONE" "0.0,0.0,0.0"))
  (print (strcat "Elapsed: "(rtos (* 0.001 (- (getvar "Millisecs") #BS)))))
  (setvar 'CMDECHO 1)
Command: (progn
(_> (BenchVBA 10000)
(_> (repeat 10 (BenchVBA 10000))
(_> )
"Elapsed: 16.5"
"Elapsed: 16.406"
"Elapsed: 16.437"
"Elapsed: 16.437"
"Elapsed: 16.437"
"Elapsed: 16.5"
"Elapsed: 16.532"
"Elapsed: 16.485"
With VBA loaded:
Command: (progn
(_> (command "_.VBASTMT" "ThisDrawing.SetVariable \"UserS1\", \"Test\"")
(_> )
"Elapsed: 16.609" _.VBASTMT
Expression: ThisDrawing.SetVariable "UserS1", "Test"
Command:
"Elapsed: 21.625"
"Elapsed: 21.641"
"Elapsed: 21.594"
"Elapsed: 21.578"
"Elapsed: 22.14"
"Elapsed: 21.735"
"Elapsed: 21.687"
"Elapsed: 21.64"
"Elapsed: 21.579"
"Elapsed: 22"
speed reduction is appreciable but NOT progressive (not depending by the number of commands performed) as with VBA6.
Grrr1337
« Reply #50 on: September 08, 2017, 03:25:02 PM »
No worries, your contribution to this forum is alot anyways.
I just liked the idea you mentioned, about creating and running temporary .dvb files thru lisp, so with my previous question I wanted to see is such technique 'worthy'. :)
vevo.bg
« Reply #51 on: September 08, 2017, 11:00:56 PM »
Awesome comment -- thank you -- I will be worthy it some day.
Any automation that takes minutes to produce that increases efficiency, accuracy ... or reduces waste, errors ... ad infinitum is worthy.
And then some.
MSTG007
« Reply #52 on: September 08, 2017, 11:09:11 PM »
Watch out... we might drain you with all our wacko ideas
Civil3D 2020
« Reply #53 on: September 08, 2017, 11:19:58 PM »
I've observed a wide spectrum of ideas during my tenure here and few if any qualify as wacky. My only frustration is having nominal time to play and thus having to cherry pick one of every hundred or so challenges that are interesting yet can be solved quickly -- and of some benefit to the swamp community, me or those I serve -- ideally all three.
Marc'Antonio Alessi
  • Marco
« Reply #54 on: September 10, 2017, 05:45:19 AM »
I apologize if I insist but i am interested in knowing if AutoCAD + VB7 has solved the problems that had AutoCAD + VB6 / 64bit.
The second question is why in A2017 I get an error: INTERNAL ERROR: VL namespace mismatch?
(defun C:TVBA (/ NewDoc FlsLst)
  (or *AcadApp* (setq *AcadApp* (vlax-get-acad-object)))
  (or *AcAcDwg* (setq *AcAcDwg* (vla-get-ActiveDocument *AcadApp*)))
  (or *AcDrwgs* (setq *AcDrwgs* (vla-get-documents *AcadApp*)))
  (setq FlsLst
   '("Z:/Temp/Test/Dwg1.dwg"
     "Z:/Temp/Test/Dwg2.dwg"
     "Z:/Temp/Test/Dwg3.dwg"
     "Z:/Temp/Test/Dwg4.dwg"
  (close (open "Z:/Temp/Test/Report.txt" "w"))
  (foreach ForElm FlsLst ; Drawing list
      (vl-catch-all-error-p
         (setq NewDoc (vl-catch-all-apply 'vlax-invoke-method (list *AcDrwgs* 'Open ForElm :vlax-false)))
        (alert (vl-catch-all-error-message NewDoc))
        (setq NewDoc nil)
      (vl-cmdf "_.VBASTMT" "documents.item(documents.count-1).sendcommand \"(load \"\"ExeTest\"\")\n\"")
  );foreach
; File to load and run every dwg > ExeTest.lsp
(defun ExeTest (DwgNam / FilPtr)
  (setvar 'CMDECHO 0)
  (setq FilPtr (open "Z:/Temp/Test/Report.txt" "a"))
  (repeat 10000
    (command "_.POINT" "_NONE" "0.0,0.0,0.0") (command "_.ERASE" "_LAST" "")
    (command "_.LAYER" "_OFF" "*" "" "") (command "_.LAYER" "_ON" "*" "")
  (write-line (strcat DwgNam "  Elapsed: "(rtos (* 0.001 (- (getvar "Millisecs") #BS)))) FilPtr)
  (setvar 'CMDECHO 1)
  (close FilPtr)
  (if (= (getvar "DBMOD") 0) (vl-cmdf "_.CLOSE") (vl-cmdf "_.CLOSE" "_Y"))
(ExeTest (getvar "DWGNAME"))
Results:
A2013
(ExeTest (getvar "DWGNAME")) > Drawing1.dwg  Elapsed: 8.86 > No VBA
(c:tvba):
Dwg1.dwg  Elapsed: 92.032
Dwg2.dwg  Elapsed: 97.109
Dwg3.dwg  Elapsed: 92.187
Dwg4.dwg  Elapsed: 89.125
A2017
(ExeTest (getvar "DWGNAME")) > Drawing1.dwg  Elapsed: 8.688 > No VBA
with A2017
Command:_.VBASTMT Initializing VBA System...
Expression: documents.item(documents.count-1).sendcommand "(load ""ExeTest"")
Command: "\n*** INTERNAL ERROR: VL namespace mismatch\n"" type Y to reset: "y
Manual test
(vl-cmdf "_.VBASTMT" "documents.item(documents.count-1).sendcommand \"(load \"\"ExeTest\"\")\n\""):
Dwg1.dwg  Elapsed: 8.921
« Reply #55 on: September 10, 2017, 09:35:34 AM »
Sorry I missed your posts Marc and I'm just heading off to work. That said, and it's a wild assed blurry eyed haven't had coffee yet guess, try:
(setq
(I'm guessing) There's nominal speed gains to be realized by trying to leverage the values between calls as globals and it may be the source of the problem. As for the other question I cannot answer at present as I've only access to AutoCAD 2012 and 2015 currently.  Thanks for your valued investigations in this thread. Cheers.
Marc'Antonio Alessi
  • Marco
« Reply #56 on: September 12, 2017, 08:03:06 AM »
(setq
The problem is not due to this (the function only run once).
VBA 7 is for >= A2014 see:
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/Unable-to-download-VBA-Enabler-for-previous-versions-of-AutoCAD.html
Try this simple test (A2013 and VBA 6):
Comando: (progn
(_>   (setvar 'CMDECHO 0)
(_>   (setq #BS (getvar "Millisecs"))
(_>   (repeat 10000
((_>     (command "_.POINT" "_NONE" "0.0,0.0,0.0") (command "_.ERASE" "_LAST" "")
((_>     (command "_.LAYER" "_OFF" "*" "" "") (command "_.LAYER" "_ON" "*" "")
((_>   )
(_>   (print (strcat "Elapsed: "(rtos (* 0.001 (- (getvar "Millisecs") #BS)))))
(_>   (setvar 'CMDECHO 1)
(_>   (princ)
(_> )
"Elapsed: 9.88"
Comando: VBASTMT
Inizializzazione del sistema VBA in corso...
Espressione: *Annulla*
Comando: (progn
(_>   (repeat 10000
((_>   )
(_>   (princ)
(_> )
"Elapsed: 20.69"
With VBA 7 the difference after the load of VBA is lower but I can not use:
due to error:
« Reply #57 on: September 12, 2017, 08:41:58 AM »
That performance hit is unfortunate if it cannot be resolved. Guess it means one has to be judicious in VB's use -- sometimes the performance hit is will be worth it when VB hosted automation yields big benefits, dumping the session when the tasks are complete.
I believe you're getting the VL namespace mismatch error because you're trying to load lisp into a document that is not active.
Said another way, there's no guarantee documents.item(documents.count-1) will return the active document.
Have you tried:
Command: _.VBASTMT
Command: activedocument.sendcommand "(load ""ExeTest"") "
Cheers.
« Reply #58 on: September 12, 2017, 09:04:20 AM »
On the performance hit -- if you unload all the vba projects (this can be done programmatically) performance returns to normal even tho the vba editor is still alive. Cheers.
Marc'Antonio Alessi
  • Marco
« Reply #59 on: September 12, 2017, 04:06:18 PM »
Maybe I can not explain well (my english is not very good) ...
There is no VBA project loaded only: Command:_.VBASTMT Initializing VBA System...
