Author Topic: Removing StrikeThrough text  (Read 1474 times)
Jeff H
« on: August 01, 2017, 06:51:59 PM »
Any ideas on the best approach for removing text with strikethrough formatting, but does not affect any other formatting ?
The example below removes all text with strikethrough formatting, and text that matches without strikethrough formatting because it uses String.Replace which replaces all occurrences in string.
I tried using MTextFragmentCallback so I could use MTextFragment.Strikethrough to avoid parsing each character but without somehow indexing where the fragment is I see no other choice.
Looking at MText.Contents looks like strikethrough text is wrapped in{\K.......} or {....\K....\k....} if nested inside other formatting. I'm guessing I will need to find the position of strikethrough format codes and use String.Remove to remove them?
Code - C#: [Select]
  1.         [CommandMethod("RemoveStrikethroughText")]
  2.         public void RemoveStrikethroughText()
  3.         {
  4.             using (Transaction trx = Doc.TransactionManager.StartTransaction())
  5.             {
  6.                 PromptEntityOptions peo = new PromptEntityOptions("\nSelect Mtext or table");
  7.                 peo.SetRejectMessage("\nNot Mtext or table");
  8.                 peo.AddAllowedClass(typeof(MText), true);
  9.                 peo.AllowObjectOnLockedLayer = true;
  10.
  11.                 PromptEntityResult per = Ed.GetEntity(peo);
  12.                 if (per.Status != PromptStatus.OK)
  13.                 {
  14.                     return;
  15.                 }
  16.                 List<string> frags = new List<string>();
  17.                 MTextFragmentCallback cb = (frag, obj) =>
  18.                 {
  19.                     if (frag.Strikethrough)
  20.                     {
  21.                         frags.Add(frag.Text);
  22.                         Ed.WriteLine($"Removing: {frag.Text}");
  23.                     }
  24.
  25.                     return MTextFragmentCallbackStatus.Continue;
  26.                 };
  27.                 MText mt = per.ObjectId.GetDBObject<MText>(OpenMode.ForWrite);
  28.                 mt.ExplodeFragments(cb);
  29.                 foreach (var frag in frags)
  30.                 {
  31.                     mt.Contents = mt.Contents.Replace(frag, String.Empty);
  32.                 }
  33.
  34.                 trx.Commit();
  35.             }
  36.         }
  37.
