Author Topic: Set default page setup  (Read 5309 times)
BlackBox
Re: Set default page setup
« Reply #15 on: May 24, 2022, 12:48:31 PM »
No worries; do what's best for you.
Updating the XML is easy, and part of the Autoloader mechanism, which has been Autodesk's method for supporting apps since +/- 2012 version. It's also how I implement custom system variables, etc in a host of other apps.
You don't have to compile anything, I just offered source code for those that prefer to. The .NET API can do a lot of things, so offering the source code was just a way of building other's trust in what I post.
Happy coding! :beer:
David Hall
  • Automatic Duh Generator
« Reply #16 on: April 03, 2023, 02:31:15 PM »
Try the following:
  1. (defun applypstolayouts ( cfg / doc rtn )
  2.     (if
  3.         (setq rtn
  4.             (not
  5.                 (vl-catch-all-error-p
  6.                     (setq cfg
  7.                         (vl-catch-all-apply 'vla-item
  8.                             (list
  9.                                 (vla-get-plotconfigurations
  10.                                     (setq doc
  11.                                         (vla-get-activedocument
  12.                                             (vlax-get-acad-object)
  13.                                         )
  14.                                     )
  15.                                 )
  16.                                 cfg
  17.                             )
  18.                         )
  19.                     )
  20.                 )
  21.             )
  22.         )
  23.         (vlax-for lay (vla-get-layouts doc)
  24.             (if (= :vlax-false (vla-get-modeltype lay))
  25.                 (vla-copyfrom lay cfg)
  26.             )
  27.         )
  28.     )
  29.     rtn
  30. )
Call with name of Page Setup:
  1. (applypstolayouts "mypagesetup")
Will return T if Page Setup is valid, else nil; excludes Model tab.
Hey Lee, I am running it, and it returns T, but the layout is not updating.  Any ideas?
David Hall
« Reply #17 on: April 03, 2023, 02:34:10 PM »
issor10
  • Mosquito
« Reply #18 on: February 22, 2024, 03:10:33 PM »
I was trying to run the following code, but I am getting a "malformed list on input" error when I try to load it into cad.
        (setq rtn
            (not
                    (setq cfg
                            (list
                                    (setq doc
                                cfg
(defun c:test6 ( )
  (applypstolayouts ("22x34")
issor10
  • Mosquito
« Reply #19 on: February 22, 2024, 03:12:16 PM »
I figured it out...
(defun c:test6 ( )
  (applypstolayouts "22x34")
