oh... ok thank you..
what would you like to have as result ?
do you want that dialog box keep last position and size
or reset to middle of screen ?
I will put new reactor when switching drawing and refresh dialog box.
Just following your good work.
Would it be too difficult to make the box location a user selectable setting?
Hi MJfarrell,..
I've made few test on dialog position,...
the thing is that the dialog actually keep the last position and size for each session of AutoCAD,..
so the request is that you need to set dialog position and size when starting AutoCAD,...right ?
