Author Topic: OVLIDE a new online lisp editor  (Read 11505 times)
bilançikur
« on: July 25, 2017, 04:55:44 AM »
Maybe something interesting to show over here;
I am still a ZWCAD user (since 2014) and that I still use ObjectDCL in the ZWCAD 2014 Plus version in combination with the ODCL_LM extension. Our company has 6 users working with the tools I created.
The only thing that bugs me for a long time is the lack of a decent editor. The best I came up with is Notepad++ with extension set to .lsp but you can imagine it is nowhere near the good old VLIDE.
As you can imagine I do keep track of what is happening with ObjectDCL and every now and then I contact them for support (wich is great as you may all know Andrea).
I noticed (on the website) he is planning to bring a new tool called 'OVLIDE'. I guess it is a nearly impossible job to do but I wouldn't be surprised if he'd pull it off.
After contacting ObjectDCL I know the intention is that this new editor will be an online editor wich connects directly into any CAD software in real time! (ZWCAD, BRICSXAD, NANOCAD, etc..) and that the lisp is passed to the CAD program... how do you even come up with such ideas.
It would be really awesome, Good luck ObjectDCL!
Here is a screenshot:
Andrea
Re: OVLIDE a new online lisp editor
« Reply #1 on: July 25, 2017, 10:47:16 AM »
Thank you Bilancikur
You are right, My Idea is to provide an online Lisp Editor for CAD.
similar to codeanywhere or icecode, however,.. these do not provide lisp coding...
evenmore, do not allow to be connected directly to the user cad program.
my idea is to create an editor able to shared with other programmer their project and use it as partnership concept.
this editor is in a test mode actually and will provide basic function for the first release.
also, we will try to implement diffrent compilator mode and iseful function like patenthese lookup etc..
I'm curious to know what can be done and always push my imagination foward. :)
thank you for sharing this new idea.
ps: are you Christopher ?
Keep smile...
PKENEWELL
« Reply #2 on: July 26, 2017, 03:55:28 PM »
Andrea: An older editor called LispLink used to have the functionality of loading the lisp file being edited into the CAD Application or loading a selection of text into the application. LispLink is now defunct (unfortunately the owner passed away), but the concept is almost as good in my opinion as directly working in the application. VLIDE with the direct step into is the best, but I would be happy to have a "Load into application" button in the editor.
Just an Idea / Thought for you.
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
Andrea
« Reply #3 on: July 26, 2017, 05:13:55 PM »
Hi  PKENEWELL
I didn't know about lisplink,...never use it.
the "load into application" will be there,..this is a must.
but,..it will provide much more in the future..
below, a simple current screenshot tooked few min ago..
we are actually implementing diffrent coloration text, and making few basic tests.
if you have any idea to share,..please don't be shy.
Thanks.
Keep smile...
PKENEWELL
« Reply #4 on: July 27, 2017, 09:50:00 AM »
Thanks Andrea! It's looking great so far.
Some things I would suggest if you are not already doing them:
1) Ability to alter the syntax coloring to your preference.
2) A "list of defined functions" panel for the current file (defuns).
3) An ASCII Chart panel (or some AutoCAD reference items, like MTEXT Codes, Field Codes, etc...)
4) Block comment / uncomment.
I currently use PSPad by Jan Fiala and have kept the syntax file up to date regularly. It has many nice features including those above, but I still need to come up with a macro / script to do loading into AutoCAD (or another clone). Haven't figured out how to do that yet.
Andrea
« Reply #5 on: July 27, 2017, 10:33:29 AM »
for the moment,..we have 35 diffrent coloring theme who can be selected,..but these will be only for test. the ultimate coloring project will be custom by user.
actually done,..but working on few fix.
in fact,..the list of improvement is really huge,..
Autocomplete sentence, snippet code library, group code, put and link comment outside the box, link reference to specific words, help, wiki link, forum links etc..
in my list,..but this will not be on the first release.
Thank you for sharing your comments.
I take all.
Keep smile...
« Reply #6 on: July 27, 2017, 10:59:08 AM »
I'm not sure what demand there is for an on line lisp editor but I give you full props for pursuing the concept and know the minimum result will be significant augmentation to your already impressive skill set. Wishing you mad success Andrea.
PKENEWELL
« Reply #7 on: July 27, 2017, 02:43:16 PM »
I take all.
No Problem Andrea. Keep up the good work! You definitely are one of the most creative programmers in Visual lisp I have seen and really push the boundaries of what can be done!  :lmao:
Andrea
« Reply #8 on: July 27, 2017, 03:31:35 PM »
Thank you Guys,..
I'll try to make something cool..
The idea creating this on web have some advantage,...
-No installation
-Share document
-work in parnership
-Automatic Web Backup
-Code with your Iphone
-Use for other CAD software,..BricsCAD, ZwCAD, NanoCAD, IntelliCAD,...etc..
-is a Web Editor, so less conflict with Personal Environnement Machine.
-More space on HardDrive.
etc...
sure, if you have no internet connection,...you can not use it.
but for most people who have AutoDesk server licenses,..you can'T even use autoCAD so..
Internet is present in our life,...and it must be present to use some software requiring licenses.
but I want to push the machine for future,..
and allow programmer to have the best information of each function and sub function with code snipet, demo and help link..and or videos..  even more,..configure your preferences for help files and even videos..and set autosearch on web and/or specific Network...  maybe i'm crasy,..but the ideas aren't missing
...but one thing at the time..the first release will be very basic.
I hope that you will like it.
Thank you.
Keep smile...
Andrea
« Reply #9 on: February 02, 2018, 07:51:23 PM »
Hi All,..
Finally, first version has been released..
OVLIDE
Help file can be found HERE
OFC plugin for CAD can be downloaded HERE
website: www.objectdcl.com
for any question/request/comments you can write me here or : support@ductisoft.com
Thank you.
also,..OVLIDE comes now with ENTGETUI (see gif)
Andrea.
« Last Edit: February 02, 2018, 08:00:16 PM by Andrea »
Keep smile...
« Reply #10 on: February 02, 2018, 10:08:23 PM »
Nicely done Andrea, you’re a man after my own heart.
Andrea
« Reply #11 on: February 03, 2018, 02:47:38 PM »
I think This tool is the beginning of a new concept...working from PC via web,....never done before in LISP.  :)
but it work. that's the important thing,...now all I have to do,..is to implement new features and options....lot of work.. :)
Keep smile...
Atook
  • AKA Tim
« Reply #12 on: February 03, 2018, 04:27:08 PM »
Really cool Andrea, congrats. :)
Andrea
« Reply #13 on: February 04, 2018, 09:08:35 PM »
thanks.. :)
Keep smile...
« Reply #14 on: February 05, 2018, 09:30:26 AM »
Andrea,
Is Ovlide supposed to integrate with AutoCAD? I messed around with it a bit this weekend and could not figure it out. Using AutoCAD 2017 on Windows 10 Pro x64.
