Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
.NET-print to bluebeam
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: .NET-print to bluebeam (Read 1743 times)
Bryco
Water Moccasin
on:
July 17, 2017, 05:52:42 PM »
I have bluebeam revu 64 standard and am having problems using .net and the bluebeam driver to create a usable pdf (Error opening file).
Had no problems with adobe, and no problems with the acad dwg to pdf driver (That is until acad made every txt and mtext that uses .shx fonts a comment w/ a box around it).
So I am basically using Kean's MultiSheetPlot(). But something is missing on bluebeam side and it (corrupt file)
Logged
Bryco
Water Moccasin
Re: .NET-print to bluebeam
Reply #1 on:
July 17, 2017, 08:27:24 PM »
made a mess of that.
Since it needed FILE NAME I thought print to file had to be true. When true it only makes .plt files
pe.BeginDocument(pi, doc.Name, null, 1,false, sFile);
//pe.BeginDocument(pi, doc.Name, null, 1, true, sFile);
Logged
MickD
King Gator
(x-in)->[process]->(y-out) ... simples!
WWW
Reply #2 on:
July 17, 2017, 08:32:38 PM »
when you don't have a duck, talk to the Swamp
Logged
- John Carmack
- J.R.R. Tolkien
Bryco
Water Moccasin
Reply #3 on:
July 18, 2017, 11:20:54 AM »
Good point Mick
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
