Author Topic: retreive ename from string  (Read 3701 times)
Andrea
« on: July 11, 2017, 10:06:25 AM »
Hi all,..
in some existing lisp....ther is a value created in XDATA as a string like this:
"(<Entity name: c5481b5d30>)"
so I don'T know why this guy made this things,..
but now i'm trying to retreive theses entities.
I mean,...to get
<Entity name: c5481b5d30>using (car (read (... doenst work..
even more,....there is mix up with "(#<VLA-OBJECT IAcadBlockReference 000000c5483955a8)"
so maybe there is another way..that I dont know.
thank you for your help.
Keep smile...
kpblc
Re: retreive ename from string
« Reply #1 on: July 11, 2017, 10:27:22 AM »
I see only one way (too slow, too stupid): check all database and compare entity pointers to this string.
Sorry for my English.
Andrea
« Reply #2 on: July 11, 2017, 10:30:33 AM »
this is exacly what the program do...and I can tell you how slow it is... :(
so that's why I want to change his method,..
the fact is that it must work in existing drawing who contain this information..
so i'm trying to find a work around.. :tickedoff:
actually I've replaced the ename and vl-name by the Handle name,....much faster with handent
but I've some issue also with this,..because handle seem can not be retreived for entities in XREF.
« Last Edit: July 11, 2017, 10:34:18 AM by Andrea »
Keep smile...
roy_043
  • BricsCAD 18
« Reply #3 on: July 11, 2017, 10:51:46 AM »
32 bit BricsCAD:
: (setq enm (car (entsel)))
Select entity: <Entity name: 19157418>
: (setq str (vl-string-right-trim ">" (substr (vl-princ-to-string enm) 15)))
"19157418"
: (KGA_Math_Hex_To_Dec str)
420836376
: (vla-get-objectid (vlax-ename->vla-object enm))
420836376
Note: enames will change between sessions. So storing them in Xdata makes little sense.
« Last Edit: July 11, 2017, 10:54:50 AM by roy_043 »
« Reply #4 on: July 11, 2017, 10:57:53 AM »
32 bit BricsCAD:
"19157418"
420836376
420836376
Precisely .. handles make more sense.
Andrea
« Reply #5 on: July 11, 2017, 11:13:12 AM »
32 bit BricsCAD:
"19157418"
420836376
420836376
is Briscad use only numeric value ad objectID ?
in autoCAD :
<Entity name: bd3fe7c660>
Keep smile...
roy_043
  • BricsCAD 18
« Reply #6 on: July 11, 2017, 11:20:12 AM »
The ename is a hex value, same as AC, hence KGA_Math_Hex_To_Dec.
Andrea
« Reply #7 on: July 11, 2017, 11:25:06 AM »
any chance to share  KGA_Math_Hex_To_Dec function ?
I've supposed to use LeeMac LM:Hex->Dec function who generate diffrent result.
(LM:Hex->Dec "c5481b5d30")
;3.04634e+12
Keep smile...
Andrea
« Reply #8 on: July 11, 2017, 11:40:38 AM »
maybe if I can't retreive object from handle name inside an XREF,..
(setq item (car (last (nentsel))))
  ;<Entity name: bd33651530>
(setq hand (cdr (assoc 5 (entget item))))
  ;"27B"
(handent hand)
  ;nil <---- ???
Keep smile...
roy_043
  • BricsCAD 18
« Reply #9 on: July 11, 2017, 11:50:43 AM »
The function I have used will not work properly if the hex value exceeds the 32 bit range.
Try:
(rtos (LM:Hex->Dec "c5481b5d30") 2 0)
FWIW my function:
; (KGA_Math_Hex_To_Dec "7FFFFFFF") => 2147483647
; (KGA_Math_Hex_To_Dec "37CD")     => 14285
; (KGA_Math_Hex_To_Dec "0")        => 0
(defun KGA_Math_Hex_To_Dec (str)
  (KGA_Math_Base_To_Dec str 16)
; (KGA_Math_Base_To_Dec "11111111" 2) => 255
; (KGA_Math_Base_To_Dec "37cd" 16)    => 14285
(defun KGA_Math_Base_To_Dec (str base / i)
  (setq i -1)
  (fix
    (apply
      (mapcar
        '(lambda (a)
          (* (- a (cond ((<= a 57) 48) ((<= a 90) 55) (87))) (expt base (setq i (1+ i))))
        (reverse (vl-string->list str))
roy_043
  • BricsCAD 18
« Reply #10 on: July 11, 2017, 11:58:49 AM »
The handent function only works for the current document. Try using the HandleToObject method instead.
Andrea
« Reply #11 on: July 11, 2017, 12:31:29 PM »
oh.. maybe this can help me...never use it,..
how the syntax must be ?
(vla-HandleToObject (vla-get-ActiveDocument (vlax-get-acad-object)) handle) return me :
Automation Error. Unknown handle
Keep smile...
« Reply #12 on: July 11, 2017, 12:54:00 PM »
Logic suggests you would have to open the hosting XREF as an ODBX doc, and then invoke the HandleToObject method from said doc.
i.e.
(if (eq 'vla-object (type (setq object (vl-catch-all-apply 'vla-HandleToObject (list ODBX handle)))))
    (rock_and_roll_with object)
    (sad_trombone)
Untested & no time to play.
« Reply #13 on: July 11, 2017, 01:01:04 PM »
<works>
« Reply #14 on: July 11, 2017, 01:08:55 PM »
That's why I love this place.
The impossible just takes longer and finding the right guy.  8)
