Author Topic: Changing pipe styles  (Read 4459 times)
zombies640
« on: June 11, 2017, 01:14:35 AM »
Hey guys, playing around with editing pipe data and thought about changing the styles with a click. I keep getting a "Parameter incorrect" error on the "oPipe.Style.Name = newName" line...not sure if I can do it this way or if I have to do something with the database first...
Edit: Hang on...might have figured it out...will post my results as a new post.
« Last Edit: June 11, 2017, 02:09:24 AM by zombies640 »
zombies640
Re: Changing pipe styles
« Reply #1 on: June 11, 2017, 02:27:51 AM »
Okay, figured it out. I was trying to directly set the pipe style by specifying the string, but after looking at the example code, I found that I needed to access the style names from the collection.
BIGAL
  • 40 + years of using Autocad
« Reply #2 on: June 12, 2017, 12:24:41 AM »
You may be interested did something similar with the contours I have them changing via a Toolbar with the preset values as icons. Again change the style. Avoids the need to use Toolspace.
