Author Topic: Access Civil 3D application database through ODBX  (Read 1328 times)
alanjt
  • Standby for witty remark...
« on: June 08, 2017, 10:02:15 AM »
In Civil 3D, is it possible to access the AeccXUiLand.AeccApplication interface with ODBX?
Dropbox
MSTG007
Re: Access Civil 3D application database through ODBX
« Reply #1 on: June 08, 2017, 11:43:51 AM »
That would be cool. What things are you thinking about doing with it?
Civil3D 2020
« Reply #2 on: June 08, 2017, 01:46:54 PM »
Using the .NET API you can interact with C3D objects in a different database. I was never able to do the same using the COM API. However, even though you CAN do it, doesn't mean it's always a good idea. :-) More specifically, editing a C3D dwg while it is not open in the Editor, and subsequently saving the dwg, often leads to unwanted results when you have Line/Curve Tags and Tables....the tags will get wiped out, almost every time, especially if they are labeling Xref and/or Dref objects.
