Ok...here is another reason why I think the achitectural types have the hardest job ...
Today, I received yet another change order from a client, not that I am not renumerated for making the changes, BUT....this set of changes was 15 pages long as typed in MS Office ... there have been at least 5 other change orders in the last 30 days that have been 9, 24, 21, 7, and 16 pages respectfully..... many of the changes are simply changes of the previous changes changing the changes of a previous change....it gets so damned confusing at times ...
"So which change did you want to eliminate"
"Item 17 on page 4, of the revisions dated 10/13/04"
"Sir that item modifies a change from a previous change from 9/29/04, what portion of the change do you want to remove?"
"Only the portion from 9/29/04 that was not changed on 10/13/04"
"So you want to completely change the change dated 9/29/04 to a compilation of the ones dated 10/13/04 and 10/23/04"
"No, I want to include these changes, but not change the changes of 10/13/04, ony the changes of 9/29/04"
"Ok, so if I understand you correctly then, the changes dated 9/29/04 are to be used as the base when determining how the changes of today (10/23/04) apply?"
"Yes, except don't change the changes dated 10/13/04"
"Sir, the changes dated 10/13/04, completely redesigns the second floor and portions of the basement, do you want the floor plan to be the same as the 10/13/04 revisions?"
"NO!!, I told you to use the revisions from 9/29/04, not 10/13/04... I DON"T WANT THOSE CHANGED!!!"
"But sir, these changes will change the plans as dated 10/13/04, because the changes of today (10/23/04) only apply to the floor plan as it was presented on 9/29/04"
"Just make it look like it did on 9/29/04"
"So you want to do away with the changes on 10/13/04 completely?"
"No, only the changes that affect the floorplan as dated 10/13/04"
"Sir, the whole floorplan changed"
"No, only the second floor and basement changed, we didn't change the first floor"
"Correct, but since we didn't change the first floor plan either time, then I presumed we were not talking about changing the first floor plan anyway?
"Oh, ok, but I have changes for the first floor plan that we'll need to look at, because when I make the changes to the first floor plan that I am thinking about, it will require that I rearrange the second floor and basement plans."
"Oh, I see, so you are really not settled on a second floor plan, except that it has to work with the first floor plan"
"Oh no, I have an idea how I want the second floor to look, sort of like the changes we talked about on 9/29/04, but you might have to change them later when I change the first floor"
ARGHHHHHHH and so the saga continues .....
Sometimes I hate dealing with people ....
