hi guys,
i need help, i rly looked up on internet but i have not found a solution yet.
i need theese codes which are given below in vba. like "select pline and done !" <3
pls help me.
kerry's code. he has a wonderfull code. (respect)
(defun c:remove-vertex ( / CNT EPOINT INDEX INDEXLIST NAME NEWLIST OBJENT VERTEXLIST)
;;; kwb 20050519
(and (setq objent (vlax-ename->vla-object (car (entsel))))
(vl-position (setq name (vlax-get objent "ObjectName")) '("AcDbPolyline"))
;"AcDb2dPolyline" "AcDb3dPolyline"))
(setq vertexlist (vlax-get objent "Coordinates"))
(while
(and (setq epoint (getpoint "Select Vertex to remove"))
(setq cnt 0
newlist '()
index (* 2 (fix (+ 0.5 (vlax-curve-getparamatpoint objent epoint))))
(setq indexlist (list index (1+ index)))
(foreach ordinate vertexlist
(if (not (vl-position cnt indexlist))
(setq newlist (cons ordinate newlist))
(setq cnt (1+ cnt))
(not (vl-catch-all-apply 'vlax-put
(list objent "Coordinates" (reverse newlist))
