Author Topic: inserting block reopens DCL form  (Read 5151 times)
jhadams82
  • Mosquito
« on: May 12, 2017, 12:15:52 PM »
Hi all!  First time poster here.  Sorry if this has been answered before, I tried to search but didn't find anything.
I only recently started using Autocad this past January, but I have a programming background so I quickly discovered LISP and eventually OpenDCL.  I'm trying to make a large program that automates part of my job and this is just one piece of the puzzle.  What I want to do is have a form that gets user input about the project and fills in some MTexts with that info.  That part works pretty well so far (tho once you guys get a look at my code, I bet there's a better way to do it :tongue2: ), but the next part is messing up the routine.
Once the user has filled in the form and hit submit, I populate some variables, close the form, then update the Mtext contents with the variables.  Here's where it gets weird.  Then I call the "insert" command and instead of inserting the block, it reopens the form and asks for the block name!  If I remove this line and put it in it's own c:function and have the user call it separately, it works fine.  So weird.  Having a separate function works for now, but eventually I want this thing to run all on it's own without stopping.  Anybody have a clue what's going on or a possible way around?  TIA
  1. (defun c:border_text/Form1/btn_submit#OnClicked (/)
  2.   (setq jobNum (dcl-Control-GetText border_text/Form1/tb_jobNum))
  3.   (setq projectName (dcl-Control-GetText border_text/Form1/tb_projectName))
  4.   (setq planType (dcl-Control-GetText border_text/Form1/tb_planType))
  5.   (setq address (dcl-Control-GetText border_text/Form1/tb_address))
  6.   (setq cityCountyState (dcl-Control-GetText border_text/Form1/tb_cityCountyState))
  7.   (setq mapNum (dcl-Control-GetText border_text/Form1/tb_mapNum))
  8.   (setq parcel (dcl-Control-GetText border_text/Form1/tb_parcel))
  9.
  10.   (dcl-Form-Close border_text/Form1)
  11.
  12.
  13.
  14.   (setq ob_planType (vlax-ename->vla-object (ssname (ssget '(34.2304 11.0993)) 0)))
  15.   (vlax-put-property ob_planType "TEXTSTRING" planType)
  16.
  17.   (setq ob_projName (vlax-ename->vla-object (ssname (ssget '(34.6853 10.5258)) 0)))
  18.   (vlax-put-property ob_projName "TEXTSTRING" projectName)
  19.
  20.   (setq ob_address (vlax-ename->vla-object (ssname (ssget '(35.0368 11.5858)) 0)))
  21.   (vlax-put-property ob_address "TEXTSTRING" address)
  22.
  23.   (setq ob_cityCountyState (vlax-ename->vla-object (ssname (ssget '(35.1842 10.7275)) 0)))
  24.   (vlax-put-property ob_cityCountyState "TEXTSTRING" cityCountyState)
  25.
  26.   (setq ob_jobNum (vlax-ename->vla-object (ssname (ssget '(34.5032 0.6551)) 0)))
  27.   (vlax-put-property ob_jobNum "TEXTSTRING" jobNum)
  28.
  29.   (command "-insert" "P:/CSDG Standards/AutoCAD STD/CSDG Blocks/Stamps/Jim Stamp.dwg" '(34.4163 17.5196) "" "" "")
  30. )
roy_043
  • BricsCAD 18
Re: inserting block reopens DCL form
« Reply #1 on: May 12, 2017, 12:51:12 PM »
You cannot use command calls in event handlers:
http://www.opendcl.com/forum/index.php?topic=2495.0
You should consider using attributes (attached to the 'stamp' block) instead of mtext entities. They are the more logical choice for this type of data.
jhadams82
  • Mosquito
« Reply #2 on: May 12, 2017, 01:12:32 PM »
well, that explains it!  Yep, sure enough.  I moved the "insert" command outside the event handler and it all works great.  Thanks!
