Author Topic: Find the same 2 points  (Read 1369 times)
well20152016
« on: May 08, 2017, 09:34:05 PM »
  1. Known:
  2. (
  3. ((((1296.45 11052.0 -43133.8) 55) ((-1187.54 11032.5 -43133.8) 1) ((-1186.62 7937.77 -43133.8) 39) ((1299.61 7929.88 -43133.8) 90)) a)
  4. ((((-2506.95 3496.12 0.0) 1) ((-2506.03 400.153 0.0) 39) ((-5506.95 3496.12 0.0) 21) ((-6506.95 7496.12 10.0) 44)) b)
  5. ((((806.95 11052.0 3133.8) 90) ((6506.03 700.153 9.0) 39) ((8506.95 3496.12 8.0) 25) ((9506.95 7496.12 13.0) 34)) c)
  6. )
  7.
  8.
  9. Result:
  10. (
  11. ((((-1187.54 11032.5 -43133.8) a) ((-2506.95 3496.12    0.0) b) 1)      (((-1186.62 7937.77 -43133.8) a) ((-2506.03 400.153  0.0) b) 39 ))
  12. ((((1299.61  7929.88 -43133.8) a) ((806.95 11052.0 3133.8) c) 90)     (((-1186.62 7937.77 -43133.8) a) ((6506.03   700.153 9.0) c) 39 ))
  13. )
  14.
  15.
« Last Edit: May 08, 2017, 09:54:40 PM by well20152016 »
roy_043
  • BricsCAD 18
Re: Find the same 2 points
« Reply #1 on: May 09, 2017, 12:31:51 PM »
Why is the 'known' list so complex?
Shouldn't the result look like this (see 'Added')?:
      1
      39
      90
      39
  ( ; Added.
      39
ahsattarian
« Reply #2 on: June 02, 2022, 03:10:14 AM »
Try these two routines :
  1. (defun overkill-points1 (ptlst1 fuzzy / ptlst2)
  2.   (setq ptlst2 nil)
  3.   (setq methodj1 2)
  4.   (cond
  5.     ((= methodj1 1) ;|  http://www.theswamp.org/index.php?topic=9042.msg567713#msg567713  |;
  6.      (while (setq po (car ptlst1))
  7.        (setq ptlst1
  8.               (vl-remove-if
  9.                 '(lambda (x) (and (equal (car po) (car x) fuzzy) (equal (cadr po) (cadr x) fuzzy)))
  10.                 ptlst1
  11.               )
  12.        )
  13.        (setq ptlst2 (append ptlst2 (list po)))
  14.      )
  15.     )
  16.     ((= methodj1 2) ;|  http://www.theswamp.org/index.php?topic=9042.msg593203#msg593203  |;
  17.      (setq ptlst1 (vl-sort ptlst1 (function (lambda (a b) (< (caddr a) (caddr b))))))
  18.      (while (car ptlst1)
  19.        (setq ptlst2 (cons (car ptlst1)
  20.                           (vl-remove-if
  21.                             (function (lambda (x) (equal (list (car x) (cadr x)) (list (caar ptlst1) (cadar ptlst1)) fuzzy)))
  22.                             ptlst2
  23.                           )
  24.                     )
  25.        )
  26.        (setq ptlst1 (cdr ptlst1))
  27.      )
  28.     )
  29.   )
  30.   ptlst2
  31. )
  32. (defun overkill-points2 (ptlst1 fuzzy / ptlst2)
  33.   (setq ptlst2 nil)
  34.   (while (setq po (car ptlst1))
  35.     (setq ptlst1 (cdr ptlst1))
  36.     (setq ad 1)
  37.     (foreach pt ptlst1
  38.       (cond ((< (distance (list (car po) (cadr po)) (list (car pt) (cadr pt))) fuzzy) (setq ad 0)))
  39.     )
  40.     (cond ((= ad 1) (setq ptlst2 (append ptlst2 (list po)))))
  41.   )
  42. )
