Author Topic: Nested assoc list accessor  (Read 3508 times)
Grrr1337
« on: May 06, 2017, 08:37:21 AM »
Hi fellow list manipulators,
I wanted to leave this idea I had:
  1. ; Nested assoc list accessor
  2. ; assocL - list of given accessors
  3. ; L - Nested assoc list
  4. (defun aassoc ( assocL L / r )
  5.   (vl-every (function (lambda (x) (if r (setq r (cdr (assoc x r))) (setq r (cdr (assoc x L)))))) assocL) r
  6. ); defun aassoc
Example:
  1. ; Given a List:
  2. (setq L
  3.   '(
  4.     ("A"
  5.       ("AA" ("AA1" "1aa1") ("AA2" "2aa2") ("AA3" "3aa3") )
  6.       ("AB" ("AB1" "1ab1") ("AB2" "2ab2") ("AB3" "3ab3") )
  7.     )
  8.     ("B"
  9.       ("BA" ("BA1" "1ba1") ("BA2" "2ba2") ("BA3" "3ba3") )
  10.       ("BB" ("BB1" "1bb1") ("BB2" "2bb2") ("BB3" "3bb3") )
  11.     )
  12.     ("C"
  13.       ("CA" ("CA1" "1ca1") ("CA2" "2ca2") ("CA3" "3ca3") )
  14.       ("CB" ("CB1" "1cb1") ("CB2" "2cb2") ("CB3" "3cb3") )
  15.     )
  16.   ); list
  17. ); setq L
  18.
  19. ; Results:
  20. _$ (aassoc '("B" "BA" "BA2") L) -> ("2ba2")
  21. _$ (aassoc '("C" "BA" "BA2") L) -> nil
  22. _$ (aassoc '("C" "CB" "CB3") L) -> ("3cb3")
  23. _$ (aassoc '("C" "CB") L) -> (("CB1" "1cb1") ("CB2" "2cb2") ("CB3" "3cb3"))
I'm not sure yet where I'm gonna use it, but you might have.
Feel free to share alternatives/opinions. :)
(apply ''((a b c)(a b c))
vevo.bg
Re: Nested assoc list accessor
« Reply #1 on: May 06, 2017, 10:04:17 AM »
Nice one Grrr1337 - I like that you avoided recursion even though the problem looks to be recursive on the surface.
Here's another variation:
  1. (defun nassoc ( k l )
  2.     (cond
  3.         (   (not l) l)
  4.         (   (cdr k) (nassoc (cdr k) (cdr (assoc (car k) l))))
  5.         (   (cdr (assoc (car k) l)))
  6.     )
  7. )
roy_043
  • BricsCAD 18
« Reply #2 on: May 06, 2017, 12:55:10 PM »
  1. (defun NestedAssoc (keyLst lst)
  2.   (repeat (length keyLst)
  3.     (setq lst (cdr (assoc (car keyLst) lst)))
  4.     (setq keyLst (cdr keyLst))
  5.   )
  6.   lst
  7. )
Grrr1337
« Reply #3 on: May 06, 2017, 01:27:59 PM »
Thanks for the thoughts, guys!
I was really wondering about the recursive approach - although in my head was the iterating with (vl-every).
vevo.bg
ziele_o2k
« Reply #4 on: May 06, 2017, 01:47:23 PM »
BTW, Lee's and roy's routines are a little bit faster :)
  1. (repeat 20
  2.   (setq time (getvar "MilliSecs"))
  3.   (repeat 10000
  4.     (aassoc '("B" "BA" "BA2") L)
  5.   )
  6.   (print (* (- (getvar "MilliSecs") time)1E-3) )
  7.   (princ)
  8. )
  9. 0.141 0.156 0.171 0.156 0.203 0.203 0.218 0.203 0.171 0.156 0.203 0.172 0.156 0.156 0.171 0.172 0.156 0.156 0.156 0.156
  10. (repeat 20
  11.   (setq time (getvar "MilliSecs"))
  12.   (repeat 10000
  13.     (nassoc '("B" "BA" "BA2") L)
  14.   )
  15.   (print (* (- (getvar "MilliSecs") time)1E-3) )
  16.   (princ)
  17. )
  18. 0.094 0.094 0.14 0.078 0.125 0.093 0.125 0.125 0.109 0.11 0.093 0.094 0.078 0.093 0.078 0.094 0.078 0.094 0.078 0.093
  19. (repeat 20
  20.   (setq time (getvar "MilliSecs"))
  21.   (repeat 10000
  22.     (NestedAssoc '("B" "BA" "BA2") L)
  23.   )
  24.   (print (* (- (getvar "MilliSecs") time)1E-3) )
  25.   (princ)
  26. )
  27. 0.093 0.078 0.156 0.109 0.11 0.14 0.109 0.109 0.094 0.094 0.093 0.094 0.078 0.078 0.094 0.094 0.093 0.094 0.093 0.11
  28.
« Reply #5 on: May 06, 2017, 01:53:17 PM »
Another:
  1. (defun nassoc-while ( k l )
  2.     (while (and (setq l (cdr (assoc (car k) l))) (setq k (cdr k))))
  3.     l
  4. )
ziele_o2k
« Reply #6 on: May 06, 2017, 02:05:25 PM »
Another:
  3.     l
  4. )
Fastest one :)
  1. 0.062 0.062 0.062 0.078 0.063 0.062 0.094 0.078 0.078 0.078 0.078 0.062 0.063 0.078 0.062 0.062 0.063 0.062 0.078 0.063
Grrr1337
« Reply #7 on: May 06, 2017, 04:41:43 PM »
Logically (foreach) is the one left:
  1. ; (nassoc-foreach '("B" "BA" "BA2") L)
  2. (defun nassoc-foreach ( k L )
  3.   (foreach x k (setq L (cdr (assoc x L))) )
  4. )
I guess ziele_o2k should do the speed test on his machine (so the speed would be compared on the same computer).
vevo.bg
ziele_o2k
« Reply #8 on: May 08, 2017, 06:51:19 AM »
Results similar to nassoc-while:
  1. 0.062 0.078 0.063 0.078 0.078 0.062 0.078 0.062 0.063 0.062 0.063 0.046 0.062 0.063 0.062 0.078 0.047 0.047 0.062 0.047
« Reply #9 on: May 08, 2017, 07:51:52 AM »
The efficiency will obviously be dependent on the length of the key list argument, as those solutions which iterate over the entirety of the key list will be performing assoc queries on a null list if one of the keys is not found.
Grrr1337
« Reply #10 on: May 08, 2017, 09:09:15 AM »
Yup, thats why unstoppable iterators like foreach mapcar repeat, although perform faster (cause the lack of a test function expr to mid-stop the iteration)
iterators like while vl-some vl-every, are more efficient - so they won't process the whole list (but will require the test function expr).
Just to clarify for anyone.
vevo.bg
