Author Topic: Civil 3D - Corridor: ditch transition  (Read 3817 times)
alanjt
  • Standby for witty remark...
« on: May 03, 2017, 06:49:36 PM »
I have a road: 2 lane - median with ditch - 2 lane
I'm currently using a "Ditch" subassembly.
How can I force the ditch to transition up to flatten out in the median?
Dropbox
Chris
Re: Civil 3D - Corridor: ditch transition
« Reply #1 on: May 04, 2017, 05:29:33 AM »
The only luck I've ever had was an independent ditch profile and use a slope to elevation link in combo with the ditch section
Christopher T. Cowgill, P.E.
AEC Collection 2020 (C3D)
Win 10
alanjt
« Reply #2 on: May 04, 2017, 03:19:37 PM »
Dang. I was afraid you were going to say that.
I want a constant ditch depth for the majority of the road. Maybe I can split the region, create a copy of the assembly just replacing the ditch sub with a slope to elevation link combo (as you mentioned), and tie it in that way.
On a similar note, have you ever been able to terminate a median and transition to to a normal lane (2 lanes+median+2 lanes TO lane+lane+lane? Currently I'm just removing that region and just grading it with feature lines to create a final surface - not pretty.
Dropbox
Chris
« Reply #3 on: May 04, 2017, 06:40:24 PM »
split the region is the way to go.
on you similar note, thats how we do it clean it up via featurelines and subsurfaces, you can get some of it via alignment widenings, but there is always some small transition that wont work.
Win 10
alanjt
« Reply #4 on: May 05, 2017, 09:28:03 AM »
Well, it's good to know I'm not completely doing it wrong.
Thank you, Chris.
Dropbox
