Author Topic: map the mapcar  (Read 7569 times)
Re: map the mapcar
« Reply #15 on: April 14, 2017, 10:31:47 AM »
Thanks Grrr.
Note that: (mapncar 0 (lambda (x) (reverse x)) Lst) can become: (mapncar 0 reverse lst)
Grrr1337
Re: map the mapcar
« Reply #16 on: April 14, 2017, 11:04:04 AM »
Ah, ofcourse! Well.. the point is to have fun manipulating assoc/nested assoc lists. :)
(apply ''((a b c)(a b c))
vevo.bg
gile
  • Marseille, France
Re: map the mapcar
« Reply #17 on: April 14, 2017, 11:04:17 AM »
Thanks Grrr.
Or simply: (mapcar 'reverse lst)
Lee, is there any reason you prefer use non-quoted function as argument in higher order functions? What's wrong with built in AutoLISP functions standard quoted ones?
Re: map the mapcar
« Reply #18 on: April 14, 2017, 11:12:36 AM »
No particular reason in this case, I simply overlooked it - but I agree that the function may be better written:
  1. (defun mapncar ( n f l )
  2.     (if (< 0 n)
  3.         (mapcar '(lambda ( x ) (mapncar (1- n) f x)) l)
  4.         (mapcar f l)
  5.     )
  6. )
Such that a quoted function may be supplied, consistent with standard AutoLISP functions.
Usually it becomes necessary to supply an unquoted function to avoid the use of eval or apply within the subfunction.
