Author Topic: Remove mtext overrides!  (Read 6453 times)
dubb
« on: April 10, 2017, 05:28:15 PM »
Is there a native AutoCAD command or work around to remove all mtext property overrides on multiple mtext entities?
https://cadabyss.wordpress.com/ StripMtext v5-0c doesn't work on my 2017 AutoCAD Vanilla
Try StripMtext on the attached file.
Re: Remove mtext overrides!
« Reply #1 on: April 10, 2017, 06:25:45 PM »
Attached is my version of a program to remove all formatting stored in the content of an MText object (note that other formatting options may be stored in other properties associated with the MText object and so this is not as comprehensive as StripMText).
dubb
« Reply #2 on: April 10, 2017, 06:28:50 PM »
Sweet! Thanks Lee. :yay!:
dubb
« Reply #3 on: April 10, 2017, 06:30:45 PM »
Works pretty good so far.
« Reply #4 on: April 10, 2017, 06:32:35 PM »
Excellent  :-)
MSTG007
« Reply #5 on: April 11, 2017, 07:17:51 AM »
How would this work with MLeaders? I have just added the "Multileader" piece. If selects it, but does not unformat it.
(defun c:unformat ( / *error* enx idx rgx sel str )
    (defun *error* ( msg )
        (if (and (= 'vla-object (type rgx)) (not (vlax-object-released-p rgx)))
            (vlax-release-object rgx)
        (if (and msg (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*")))
        (   (or (vl-catch-all-error-p (setq rgx (vl-catch-all-apply 'vlax-get-or-create-object '("vbscript.regexp"))))
                (null rgx)
            (princ "\nUnable to interface with RegExp object.")
        (   (setq sel (ssget "_:L" '((0 . "MTEXT,MULTILEADER"))))
            (repeat (setq idx (sslength sel))
                (setq enx (entget (ssname sel (setq idx (1- idx))))
                      str (assoc 1 enx)
                (entmod (subst (cons 1 (LM:quickunformat rgx (cdr str))) str enx))
    (*error* nil) (princ)
;; Quick Unformat  -  Lee Mac
;; Returns a string with all MText formatting codes removed.
;; rgx - [vla] Regular Expressions (RegExp) Object
;; str - [str] String to process
(defun LM:quickunformat ( rgx str )
        (null
                (setq str
                    (vl-catch-all-apply
                       '(lambda nil
                            (vlax-put-property rgx 'global     actrue)
                            (vlax-put-property rgx 'multiline  actrue)
                            (vlax-put-property rgx 'ignorecase acfalse)
                            (foreach pair
                                    ("\032"     . "\\\\\\\\")
                                    (" "        . "\\\\P|\\n|\\t")
                                    ("$1"       . "\\\\(\\\\[ACcFfHKkLlOopQTW])|\\\\[ACcFfHKkLlOopQTW][^\\\\;]*;|\\\\[ACcFfKkHLlOopQTW]")
                                    ("$1$2/$3"  . "([^\\\\])\\\\S([^;]*)[/#\\^]([^;]*);")
                                    ("$1$2"     . "\\\\(\\\\S)|[\\\\](})|}")
                                    ("$1"       . "[\\\\]({)|{")
                                    ("\\$1$2$3" . "(\\\\[ACcFfHKkLlOoPpQSTW])|({)|(})")
                                    ("\\\\"     . "\032")
                                (vlax-put-property rgx 'pattern (cdr pair))
                                (setq str (vlax-invoke rgx 'replace str (car pair)))
        str
(vl-load-com) (princ)
Civil3D 2020
« Reply #6 on: April 11, 2017, 08:03:41 AM »
Did you honestly expect it to, after only modifying the selection filter?
You would need to check whether the selected MLeaders have MText content (as opposed to block content or no content), and then unformat and update the value of the first occurrence of DXF group 304, which stores the MText content of an MLeader.
Rittik Das
  • Mosquito
Re: Remove mtext overrides! ERROR
« Reply #7 on: February 13, 2020, 06:01:01 AM »
Hello Lee, I'm a follower of yours and trying to grow my knowledge in automation. I tried you "unformat" lisp, but there is an error showing.
Before using that lisp incidentally added width factor in dxf code, which was equal with the text style width factor. :thinking:
« Reply #8 on: February 13, 2020, 12:49:24 PM »
Your width factor looks to be malformed - usually there is a semi-colon following the factor, e.g.:
(1 . "{\\W1.1;MText}")
             ^---------- Here
