Author Topic: Cable tray Outside bend less than 5 degrees  (Read 765 times)
hudster
« on: April 10, 2017, 12:10:45 PM »
Does anyone know of a way I can add a vertical outside bend to a cable tray that has a bend of less than 5 degrees?
I have a run of tray down a sloped walkway, the walkway has a 1-degree slope, along a length of 19M, resulting in a fall of 330mm.
As its an exposed services installation, I'd like to have the tray sloped to match walkway, but the standard Revit family won't allow a connection of less than 5 degrees, it's driving me nuts.
after 30 mins of fiddling, I had to walk away for risk of breaking something.
Does anyone have any ideas?
« Last Edit: April 10, 2017, 12:21:39 PM by hudster »
Master_Shake
Re: Cable tray Outside bend less than 5 degrees
« Reply #1 on: April 26, 2017, 04:21:39 PM »
