Author Topic: Layer Director.......  (Read 2239 times)
El Bachaco
« on: April 10, 2017, 11:30:11 AM »
Sr. Lee how to include in your lisp "Layer Director" an option .... that all "center" type lines, color 9, are placed in a layer named "C-12_EJES" .... having this layer Contributes to the quality of the drawings .... thank you very much and regards ....
ChrisCarlson
Re: Layer Director.......
« Reply #1 on: April 10, 2017, 11:56:49 AM »
Without extensive rewriting, I do not think that is possible. LD works upon entity creation, I would suggest a change in the way your CAD Standards are setup.
lamarn
« Reply #2 on: April 10, 2017, 03:22:59 PM »
You can write a filter (/function) that does this.
Your own commands can than be put into layer director as follow.
layerdirector:data
 ;; AutoCAD commands
("[DM]TEXT,TEXT"    "X-XX_txt__"    "NLCS text"    7 "Continuous"    25 1 nil) ; text
("DIM*"            "X-XX_dim_" "NLCS dimension" 7 "Continuous"  25 1 nil) ; dims
("*VPORT*"          "vports" "NLCS viewport" 9 "Continuous" 13 0 nil) ; vport
("*LEADER*"        "X-XX_ldr_" "NLCS leader" 7 "Continuous" 25 1 nil) ; leader
("*XL*"          "X-XX_hulplijn_" "NLCS hulp" 6 "Continuous" 13 0 nil) ; xlines
("*RAY*"            "X-XX_hulplijn_"  "NLCS hulp" 6 "Continuous" 13 0 nil) ; ray
("*WIPEOUT*"        "X-XX_wipeout" "NLCS wipeout" 7 "Continuous" 13 1 nil) ; for wipeouts
("*HATCH*"          "X-XX_hatch-AD" "NLCS hatch" 253 "Continuous" 18 1 nil) ; for hatches
("*image*"          "X-XX_image_" "NLCS image" 7 "Continuous" 13 1 nil) ; for images
("*pdfattach*"          "X-XX_pdf_" "NLCS pdfs" 7 "Continuous" 13 1 nil) ; for pdfs
("*3dface*"        "_3D_face_"     "3D face"  4 "Continuous" 35 1 nil) ; faces
("*EXTRUDE*"      "_3D_solid_extrude_" "3D extrude" 4 "Continuous" 35 1 nil) ; extrude
("*EXT"      "_3D_solid_extrude_" "3D extrude" 4 "Continuous" 35 1 nil) ; extrude
("*REVOLVE*"        "_3D_solid_revolve_"  "3D revolve" 4 "Continuous" 35 1 nil)    ; revolved
("*SWEEP*"          "_3D_solid_sweep_"    "3D sweep" 3 "Continuous" 35 1 nil)    ; sweeps
("*LOFT*"          "_3D_solid_loft_"    "3D loft" 3 "Continuous" 35 1 nil)    ; sweeps
("*POLYSOLID*"      "_3D_solid_poly_"    "3D poly" 3 "Continuous" 35 1 nil)    ; sweeps
("*section*"        "_3D_section__"    "3D section" 125 "Continuous" 25 0 nil)    ; sections
("*sectionplane*"    "_3D_sectionplane__"    "3D sectionplane" 114 "Continuous" 25 0 nil)    ; sectionplane
("*projectgeometry*"    "_3D_projectgeometry__"    "3D projectgeometry" 8 "Continuous" 25 0 nil)    ; projectgeometry
("*entopo*"    "X-XX_dim_entopo"    "entopo points and blocks" 7 "Continuous" 25 1 nil)    ; entopo
; !!! my custom command  === >  .. :)
("DNH"        "X-XX_dim_DNH"    "none-NLCS DNH hoogtemaatvoering"    7 "Continuous" 18 1 nil)
("DNHmm"        "X-XX_dim_DNH"    "none-NLCS DNH hoogtemaatvoering"    7 "Continuous" 18 1 nil)
("DNHm"        "X-XX_dim_DNH"    "none-NLCS DNH hoogtemaatvoering"    7 "Continuous" 18 1 nil)
("inladenblock" "X-XX_dim_DNH" "none-NLCS DNH hoogtemaatvoering" 7 "Continuous" 18 1 nil)
("4PS"        "_3D_4-point-solid_"    "none-NLCS 4-point solid"    7 "Continuous" 18 1 nil)
("talud"      "talud" "none-NLCS talud" 1 "Continuous" 18 1 nil)
« Reply #3 on: April 10, 2017, 03:39:35 PM »
For those without a link:
http://www.lee-mac.com/layerdirector.html
Also this is another older reactor routine you may look at.
http://www.theswamp.org/index.php?topic=22733.msg273953#msg273953
« Last Edit: April 10, 2017, 03:43:45 PM by CAB »
El Bachaco
« Reply #5 on: April 11, 2017, 04:03:38 PM »
Thank you friends for your great help ....... thanks ....
lamarn
« Reply #6 on: June 10, 2020, 05:48:12 PM »
Old userful routine, still good and functional.
Today i came across this in DraftSight.
Check it out. The interface is done well
https://youtu.be/M-dnBTsSgqs
« Last Edit: June 10, 2020, 05:52:29 PM by lamarn »
