Author Topic: combine multiple attributes to 1 with text in between  (Read 1441 times)
DraxJDM
« on: April 07, 2017, 09:29:15 AM »
hi all,
i am in a bit of trouble.
we got a bunch of drawings from a subcontractor where the attributes are mest up.
can i combine the value from multiple attributes in one ( the first one) with a "text" in between.
example  wtih the tagnames  tag: 4_1000_1 & " - "  &  tag 4_1002  , combined in tag 4_1000_1. blockname is "titleblock"
hope i can get some help
greetz John
DraxJDM
Re: combine multiple attributes to 1 with text in between
« Reply #1 on: April 10, 2017, 01:08:39 PM »
found a solution ...
taped some routines found here together  ;-)
Greetz John
ahsattarian
« Reply #2 on: December 22, 2021, 02:46:01 PM »
test    Command: BLOCKREPLACE
« Reply #3 on: December 22, 2021, 04:05:29 PM »
Greetz John
I'm honestly glad you found a solution but would you care to elaborate (I'm not sure someone who has this problem in the future will find that post very helpful)?
