You could use dynamo for this https://dynamonodes.com/2016/07/10/workflow-create-wall-opening-for-ductwork-in-revit-2016-using-dynamo/ shouldn't be too difficult to get the hole sizes to a schedule from this
Or worst case, upgrade a copy of the project models and use them for this one exercise.
it should still work, as long as the Dynamo version is the same as the example, with the relevant nosed loaded.
