Author Topic: Adding property set data to Civil 3D labels  (Read 3771 times)
Peter2
« on: April 03, 2017, 08:31:12 AM »
(cross-posting to Autodesk - Civil 3D Cutumization:
https://forums.autodesk.com/t5/autocad-civil-3d-customization/adding-property-set-data-to-civil-3d-labels-youtube-video/td-p/6981417)
Based on
"Civil 3D 2017 - Adding property set data to Civil 3D labels"
https://www.youtube.com/watch?v=qBWOV139x_E
and
How to use property sets to populate a pipe with its upstream and downstream structures in Civil 3D
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-use-property-sets-to-populate-a-pipe-with-its-upstream-and-downstream-structures-in-Civil-3D.html
Result:
The invert ("1474..."; property of the pipe) is displayed correctly
Based on property sets, only simple text (string "123" ) is displayed correctly, but formulas do not display the result but only the formula itself.
Valid for C3D 2017 with and without Enhancement 1.
Any quick ideas how to display the result?
Peter
BricsCAD V23
Re: Adding property set data to Civil 3D labels
« Reply #1 on: August 28, 2017, 09:46:09 AM »
Pretty sure you want to create an expression (formula)
Then add that expression to your pipe labels.
And post and example of your file...Just enough to see what is or isn't working for you.
Peter2
« Reply #2 on: October 16, 2017, 12:21:39 PM »
Hi Michael
thanks, but at the moment I stopped this project. Maybe will be reactivated later.
Peter
BricsCAD V23
« Reply #3 on: October 16, 2017, 12:50:40 PM »
Hi Michael
Thanks for that update....happy to assist at any time.
