Author Topic: Updating Add-ins from server  (Read 10594 times)
Jeff H
« on: March 31, 2017, 01:39:43 AM »
I will go more detail in later post if needed but attached is project that should work for 2016 and from description below and looking at code should be able to figure out how it works.
This has worked well for me for everyone getting the latest dlls, cuix, etc..  in an environment where there is a
  • local server
  • everyone has access to the server, and are mapped with same drive letter
  • for installation just sent out email with link to app.bundle folder to copy and paste into their %appdata%\Autodesk\ApplicationPlugins
  • a machine for development is connected to the server
The attachment contains the following folders with short description.
  • Server Folder - This is meant to mimic the server folder and there are few things you need to change to path of this folder
  • TheSwamp - This contains the Solution with 3 projects
    • TheSwampAddinLoader - This just opens the TheSwampAddinLoader.loadconfig file to get the "UpdateDirectory" value which should be the path of where the TheSwampAddInLoaderData.loadData file and all files that need to be copied or updated are located
    • TheSwampAddin1 - all files for this project are first copied and overwritten if newer then is loaded by TheSwampAddinLoader
    • TheSwampAddin2 - all files for this project are first copied and overwritten if newer then is loaded by TheSwampAddinLoader
  • TheSwamp.AddinLoader.bundle  This contains the app.bundle folder with TheSwampAddinLoader.loadconfig file
Here is how it works.
  • The TheSwamp.AddinLoader.bundle uses the AutoLoader functionality to load in TheSwampAddinLoader.dll.
  • It looks in same folder as TheSwampAddinLoader.dll for TheSwampAddinLoader.loadconfig file which is an xml file with "UpdateDirectory"with the location of TheSwampAddInLoaderData.loadData file. It will copy all files from "UpdateDirectory" into the TheSwamp.AddinLoader.bundle folder using the parameters set by .loadata file. In the attached project UpdateDirectory="%userprofile%\Documents\Visual Studio 2015\Projects\Server Folder\TheSwampApps\v20.1" which contains the TheSwampAddInLoaderData.loadData file and files to be copied
  • The TheSwampAddInLoaderData.loadData file tells what files type of files to copy, if it should copy sub-directories, and which files to Load into AutoCAD.
How to get it working after download and unziping.
  • Edit the ~\TheSwamp.AddinLoader.bundle\Contents\Windows\2016\TheSwampAddinLoader.loadconfig file by changing the value of "UpdateDirectory" to the location of ~\Server Folder\TheSwampApps\v20.1 where  where it resides on your computer now
  • Copy and paste the TheSwamp.AddinLoader.bundle folder to %appdata%\Autodesk\ApplicationPlugins folder
  • Start AutoCAD
  • Edit TheSwampAddin1 and/or TheSwampAddin2
  • Use the ServerRelease configuration to build project(The ServerRelease is just the Release build with output folder set to location of .loaddata file so it puts dll and any referenced dll into folder to be copied)
  • Close and Start AutoCAD
<?xml version="1.0" encoding="utf-8" ?>
<AddInLoaderUpdatePath
  UpdateDirectory="%userprofile%\Documents\Visual Studio 2015\Projects\Server Folder\TheSwampApps\v20.1">
</AddInLoaderUpdatePath>
<AddInLoaderData CopySubDirectories ="false" ExtensionFilter =".dll|.cuix|.mnr">
  <LoadFiles>
     <LoadFile>TheSwampAddin1.dll</LoadFile>
    <LoadFile>TheSwampAddin2.dll</LoadFile>
  </LoadFiles>
</AddInLoaderData>
« Last Edit: March 31, 2017, 01:44:27 AM by Jeff H »
MexicanCustard
Re: Updating Add-ins from server
« Reply #1 on: March 31, 2017, 08:00:38 AM »
Nice work Jeff.  I've been working on something similar that uses FileSystemWatcher to look for folder changes then prompts the user. If the user chooses to update, it spins up the updater, and shuts down Autocad.  The updater waits for Autocad to shut down and copies over the files then fires up Autocad again and shuts down.
Jeff H
« Reply #2 on: March 31, 2017, 09:39:40 AM »
Thanks,
If it was used for something main stream or commercially available app then would need something like you got.
Atook
  • AKA Tim
« Reply #3 on: March 31, 2017, 01:52:48 PM »
Great stuff Jeff, thanks for posting example code and an explanation.
pBe
« Reply #4 on: April 05, 2017, 11:21:28 AM »
Hi Jeff H,
Great code, one question though. I change  R20.1 to 19.0...
Code - C#: [Select]
  1. <RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD|AutoCAD*" SeriesMin="R19.0" SeriesMax="R21.0" />
It worked with versions 14,16 and 17 but not with Autocad 2015? Is it just me or there's something else that needs changing?
Thank you in advance.
pBe
Jeff H
« Reply #5 on: April 05, 2017, 12:06:17 PM »
Hi Jeff H,
Code - C#: [Select]
pBe
Not sure I had mine broken out into separate folders for each year(also the builds had a separate "Update folder") and below is what I used unmodified. It worked for 2015 and I do not see anything that would need changing. I got 2015 and will try testing it here later today with the attached example.
<?xml version="1.0" encoding="utf-8"?>
<ApplicationPackage SchemaVersion="1.0" AutodeskProduct="AutoCAD" ProductType="Application" Name="HpadCad" AppVersion="1.0.0" Description="AutoCAD Plug-in" Author="Jeff H" ProductCode="{FF4A6B1C-33C3-7DM3-8F61-423D6048EFA8}">
<CompanyDetails Name="Hpad" Phone=" " Url=" " Email="" />
<Components>
<RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD|AutoCAD*" SeriesMin="R19.0" SeriesMax="R19.0" />
<ComponentEntry AppName="HpadCad.AddinLoader" ModuleName="./Contents/Windows/2013/HpadCad.AddinLoader.dll" LoadOnAutoCADStartup="true"/>
</Components>
<Components>
<RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD|AutoCAD*" SeriesMin="R20.0" SeriesMax="R20.0" />
<ComponentEntry AppName="HpadCad.AddinLoader" ModuleName="./Contents/Windows/2015/HpadCad.AddinLoader.dll" LoadOnAutoCADStartup="true"/>
</Components>
<Components>
<RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD|AutoCAD*" SeriesMin="R20.1" SeriesMax="R20.1" />
<SystemVariables>
<SystemVariable Name="LAYERMAPSTYLE" PrimaryType="String" StorageType="Database" Value="Standard" Flags="Create"/>
</SystemVariables>
<ComponentEntry AppName="HpadCad.AddinLoader" ModuleName="./Contents/Windows/2016/HpadCad.AddinLoader.dll" LoadOnAutoCADStartup="true"/>
</Components>
</ApplicationPackage>
pBe
« Reply #6 on: April 05, 2017, 12:13:10 PM »
Thank you for the quick reply Jeff H. I will try this as soon as i get back to the work.
It's beer time :)
pBe
« Reply #7 on: April 06, 2017, 06:00:33 AM »
I'm still not getting why plugins skips 2015, it reads the XML but doesn't load the DLL.
Can you give it a try with the attached test bundle from ADN DevBlog. It runs on all versions except 2015.
Command: RunMeFirst
Unknown command "RUNMEFIRST".  Press F1 for help.
while the rest has [ 14, 16 and 17 ]
Command: RunMeFirst
Hello World
Any ideas?
Jeff H
« Reply #8 on: April 06, 2017, 09:29:17 AM »
I thought I had 2015 installed but I must of un-installed it.
For 2015 I think it should be
pBe
« Reply #9 on: April 06, 2017, 03:07:49 PM »
Jeff H,
I installed a fresh copy of Autocad 2015 on a my home computer , and what do you know, "THESWAMP" appeared on the on the Ribbon Panel. Close 2015 and restart 2015. Its still there.
I then launch Autocad 2017 and it works as expected. Yipee!!!
But wait..
Start Autocad 2015 again... gone... and the only hint i got is the "Beep" sound
Code - C#: [Select]
  1.         public void Initialize()
  2.         {
  3.             try
  4.             {
  5.                 Loader load = new Loader();
  6.                 load.Load();
  7.             }
  8.             catch (Exception)
  9.             {
  10.                 Console.Beep();  /// <--- This beep not the one on the ExtensionApplication Class
  11.                 throw;
  12.             }
  13.         }
What do you make of it?
Jeff H
« Reply #10 on: April 06, 2017, 03:52:39 PM »
Did you have 2017 and 2015 open at same time?
I have not had problems having multiple instances of acad open same or different year, but the versions had separate folders and addinloaders.
pBe
« Reply #11 on: April 07, 2017, 02:29:56 PM »
Not at the same time, I did create two sets of addinloaders [  2015/2017 ] but still no joy. still hearing the beep which means it recognize the xml.
It appears that both TheSwampAddinLoader.dll and TheSwampAddin1.dll did not finish its task. The cuix wasnt loaded and the files are not copied, also Unknown command "THESWAMP".  Press F1 for help.
The thing that gets me is it works on 14 , 16 and 17 using just one set of dlls. Were you able to test 2015 on your end?
« Last Edit: April 07, 2017, 02:36:07 PM by pBe »
Jeff H
« Reply #12 on: April 10, 2017, 09:48:00 AM »
I did use it for 2015, but uninstalled it. I am confrused also why its not working.
pBe
« Reply #13 on: April 10, 2017, 01:14:36 PM »
I ended up using this for Autocad 20105
  1. <RuntimeRequirements OS="Win32|Win64" Platform="AutoCAD|AutoCAD*" SeriesMin="R20.0" SeriesMax="R20.0" />
  2.     <ComponentEntry AppName="Appname" " ModuleName="./Contents/Resources/Company.lsp" PerDocument="True" LoadOnAutoCADStartup="true" LoadOnCommandInvocation="True"/>
  3.    <ComponentEntry AppName=""Appname"  ModuleName="./Contents/Resources/2015/Company.cuix" AppDescription="Company CuiX"  AppType="CuiX"/>
But it does not copy/update files from the Server Folder like it does for 2017. I'm not even sure loading a partial cuix from XML is a good thing.
Sure hope you anyhone can come up with an answer on why TheSwamp Loader is not working om 2015.
Question for you: Can we call an EXE file from the PackageContents.xml?
BTW: Thank for all your help.
EDIT: Makes me wonder did it ever worked on 2015 as i mentioned on the other post. I wanted it to work so bad that i imagined it working the first time
« Last Edit: April 10, 2017, 01:17:50 PM by pBe »
Jeff H
« Reply #14 on: April 10, 2017, 02:17:45 PM »
I know I used it on 2015 for months. I will see if I can find a copy of 2015 to try it on.
