Author Topic: Multi Height levels  (Read 931 times)
hudster
Multi Height levels
« on: March 22, 2017, 11:22:25 AM »
I have a model of a warehouse and it has an area which has a raised area, and its above the first-floor level, so when I add the ground floor services to this area, it's showing on the first-floor view, and not on the ground. If i extend the ground floor view range, it shows first floor services
How does everyone else deal with issues like this, (image attached as my description seemed a bit vague)
Rob...
Re: Multi Height levels
« Reply #1 on: March 22, 2017, 11:49:12 AM »
For the raise area associated with ground floor, I would use a plan region to extend the view range for that area only.
CAD Tech
Matt__W
  • I like my water diluted.
« Reply #2 on: March 23, 2017, 08:28:30 AM »
Ditto on the Plan Region.
Autodesk Expert Elite
hudster
« Reply #3 on: March 27, 2017, 12:26:18 PM »
that's what we do, just wondering if there was a better way.
