Author Topic: Help with vl-sort  (Read 2583 times)
setq and 1 Guest are viewing this topic.
velasquez
Help with vl-sort
« on: March 20, 2017, 09:01:56 PM »
In my language there are words like "Tê" "Válvula" "pé"
I'm having problems with working with vl-sort
(vl-sort '(("Tubo" "Tê" "Tão" "Válvula" "Registro"))  '(lambda (a b) (< (cadr a) (cadr b))))
;;;Returns -> (("Tubo" "Tê" "Tão" "Válvula" "Registro"))
;;; In my language, the return must be like ->  '(("Tão" "Tê" "Tubo" "Registro" "Válvula"))
Can someone give me a way?
ifncdylan
Re: Help with vl-sort
« Reply #1 on: March 20, 2017, 09:31:15 PM »
Forgive me but what language is it? :)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #2 on: March 20, 2017, 10:36:11 PM »
I'd guess Portuguese or Spanish.
Called Kerry in my other life
I live at UTC + 13.00
gile
  • Marseille, France
« Reply #3 on: March 21, 2017, 02:09:05 AM »
I don't know why you have a single list nested in a single list, but what you need is simply sort the 'car' of the parent list:
  1. (list (vl-sort (car '(("Tubo" "Tê" "Tão" "Válvula" "Registro"))) '<))
which is the same as
  1. (list (vl-sort  '("Tubo" "Tê" "Tão" "Válvula" "Registro") '<))
VovKa
  • Ukraine
« Reply #4 on: March 21, 2017, 03:30:46 AM »
use acad_strlsort
Peter2
« Reply #5 on: March 21, 2017, 04:00:17 AM »
;;; In my language, the return must be like ...
I fear that there is no common solution  :-(
For me, the only unique sorting order is "a-z" and "0-9...". All other can be discussed and defined. Is it
  • "A a B b" or "a A b B"
  • "a ä" or "ä a" or "a-z ä" (German Umlaute)
  • "â a á à or á a à â or ....(other diacritics)
  • what's about the letters which are beyond a-z? (IIRC "ck" is an own letter in Czech ....)
So maybe you have to code it for every special character ....
Peter
BricsCAD V23
velasquez
« Reply #6 on: March 21, 2017, 06:43:11 AM »
This list is part of a larger list.
velasquez
« Reply #7 on: March 21, 2017, 06:44:12 AM »
My language is Portuguese.
