David,
I found this one some time back but never tried it.
I haven't had a need for anonymous blocks.
;;AB.LSP creates an anonymous block from user
;; chosen entities
;;Written by Brian Debelius, NAI Technologies Inc., Systems Division
;;Date 1995/11/14
;; 1995/04/04 simplified code
(defun c:AB ()
;prompt user to select objects
(setq sset (ssget))
;prompt user for insertion point
(setq pt (getpoint "\nPick insertion point"))
;write block header
(entmake
(list '(0 . "BLOCK")
'(2 . "*anon")
'(70 . 1)
(cons '10 pt)
;add entities in selection set to block
;repeat for every entity in the selection set
(setq a 0)
(repeat (sslength sset)
(entmake (entget (setq ent (ssname sset a))))
;if polyline or block reference with attributes,
;walk down sub-entities until seqend is found
(if (assoc 66 (entget ent))
;add sub-entities until seqend is found
(setq subent (entnext ent))
(while (/= (cdr (assoc 0 (entget subent))) "SEQEND")
(entmake (entget subent))
(setq subent (entnext subent))
;add seqend sub-entity
;delete original entity
(entdel ent)
(setq a (1+ a))
;write block end sub-entity
(setq name (entmake '( (0 . "endblk"))) )
;insert block reference at insertion point
(entmake
(list '(0 . "INSERT")
(cons '2 name)
(cons '10 pt)
(setq sset nil)
