Author Topic: Strange behavior of NCOPY function  (Read 1820 times)
danglar
  • Read My Li(s)(p)
« on: March 07, 2017, 09:16:36 AM »
Hi folks.
I received some drawings created in Revit and converted to regular DWG file and something strange happened when I invoke NCOPY function from Express tools set:
I don't see any copied object and nested object not highlighted (see attached etransmit to check it). Actually NCOPY not working at all on these files and in a same time working properly on rest files, created in Autocad
I use acad2013 64bit I checked it on above versions and return the same issue
Probably somebody knows the reason for this issue?
danglar
  • Read My Li(s)(p)
Re: Strange behavior of NCOPY function
« Reply #1 on: March 08, 2017, 02:31:00 AM »
Hi rkmcswain!
Realy brilliant solution comes from Jef! from here:
http://www.cadtutor.net/forum/showthread.php?100032-Strange-behavior-of-NCOPY-function&p=680344#post680344
Something curious but really efficient...
And now (after setting INSBASE 0,0,0) all working fine. I understand in Revit not really nesecary to set insbase to 0,0,0 what why in almost all drawings converted from Revit I see different INSBASE,but now I can handle it well
rkmcswain
« Reply #2 on: March 08, 2017, 08:09:32 AM »
Are you the owner/operator of the website in your signature?
rkmcswain
« Reply #3 on: March 08, 2017, 05:33:57 PM »
Maybe you didn't get the notification on the last post.
*bump*
rkmcswain
« Reply #4 on: March 20, 2017, 09:27:26 PM »
