Author Topic: Multi Line or textbox with DCL  (Read 10007 times)
dubb
« on: February 17, 2017, 03:15:08 PM »
I am trying to create a textbox with DCL. I have read that DCL only supports a single line.
ObjectDCL, OpenDCL, Doslib will not work for me because I cannot install executables in my office network environment.
The goal of my next script would be to allow the user to enter multi-line text in a textbox and save it to a .txt file on the network.
Any ideas on how to achieve this?
Re: Multi Line or textbox with DCL
« Reply #1 on: February 17, 2017, 05:20:54 PM »
I've previously used a list box to display multiline text, as per this example.
Grrr1337
« Reply #2 on: February 17, 2017, 05:42:18 PM »
What about creating a list of strings and popultate the DCL code on the fly, by using paragraph and text_part:
http://www.afralisp.net/archive/lispa/lisp48u.htm
(apply ''((a b c)(a b c))
vevo.bg
« Reply #3 on: February 17, 2017, 11:36:08 PM »
This is an old routine that works with text file stored data.
I never completed the user edit portion. It was easy to edit the stored data directly.
http://www.theswamp.org/index.php?topic=1392.0
BIGAL
  • 40 + years of using Autocad
« Reply #4 on: February 18, 2017, 08:07:38 PM »
Whilst a dcl would be nice could you not just use mtext, pull the text out after closing write to file then erase it.
dubb
« Reply #5 on: February 20, 2017, 01:47:18 PM »
I like what you have done with this script, its what I'm trying to achieve.
Per other replies, I'm also going to explore those methods.
