Author Topic: Use Operator from Variable  (Read 1634 times)
mailmaverick
« on: February 15, 2017, 08:30:03 AM »
Is it possible to give + or - operators through variables ?
Such as
(setq op '+)
(op 5 2)
Result = 7
(setq op '-)
(op 5 2)
Result = 3
mailmaverick
Re: Use Operator from Variable
« Reply #1 on: February 15, 2017, 08:42:15 AM »
Found one solution using apply :
(setq op '+)
(apply op (list 5 2))
Result = 7
(setq op '-)
Result = 3
Is there any other solution ?
Grrr1337
« Reply #2 on: February 15, 2017, 08:47:41 AM »
To shed some light:
_$ (type +)
SUBR
_$ (type '+)
SYM
_$ (setq op +)
#<SUBR @000000097244fba8 +>
_$ (op 5 2)
7
_$ (eval '(op 5 2))
7
_$ (setq op '+)
_$ (apply op '(5 2))
7
EDIT: Another way would be to use the read function, so this thread is somewhat related.
« Last Edit: February 15, 2017, 08:51:43 AM by Grrr1337 »
(apply ''((a b c)(a b c))
vevo.bg
irneb
« Reply #3 on: February 15, 2017, 08:52:03 AM »
Both those would work, though only with a few tweaks. It's one of the features of Lisp in general. There's no difference between an "operator" and a function, in Lisp (all Lisp's not just AutoLisp) everything is a function or a value, and both can be assigned to a symbol.
  1. (setq op +)
  2. (op 5 2)
  3. ;; Result = 7
Or if you quote the "operator", then you need to "de-quote" it when you use it - i.e. use something like apply which takes a quoted symbol of the function instead of just the function. Thus:
  1. (setq op '+)
  2. (apply op '(5 2))
  3. ;; Result = 7
« Last Edit: February 15, 2017, 09:57:55 AM by irneb »
mailmaverick
« Reply #4 on: February 15, 2017, 09:53:47 AM »
Thanks a lot. My query is resolved.
dgorsman
« Reply #5 on: February 15, 2017, 10:14:38 AM »
I've done that in the past.  I needed a means to mass-convert drawing content in terms of layers, line types, color, and so on.  Naturally the drawings could not be counted on to even be consistently wrong.  So I built an expert system in LISP, using (apply ...) frequently to apply both math and logic rules.  Worked quite well except rules had to be constructed manually which was time consuming.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
