Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Passing a list to SSGET Logical Operators
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Passing a list to SSGET Logical Operators (Read 1423 times)
Coltm16
Guest
on:
February 03, 2017, 11:14:07 AM »
Is it possible to pass a list to an SSGET function with conditional operators, or something similar to accomplish the same thing? I've tried everything I can think of but it is not working. Example:
Code - Auto/Visual Lisp:
[Select]
setq
mylist
list
cons
8
"Layer1"
cons
8
"Layer2"
setq
ss
ssget
list
cons
4
"<OR"
mylist
cons
4
"OR>"
command
"_stretch"
ss
Thanks for any help.
Last Edit: February 03, 2017, 11:20:30 AM by Coltm16
Logged
Needs a day job
Re: Passing a list to SSGET Logical Operators
Reply #1 on:
February 03, 2017, 11:24:11 AM »
[Select]
ssget
8
"Layer1,Layer2"
Logged
Coltm16
Guest
Reply #2 on:
February 03, 2017, 12:03:54 PM »
Thanks, Have not tested it yet, but can it be:
[Select]
setq
mylistoflayers
list
"Layer1"
" Layer2"
ssget
8
. mylistoflayers
or Do i need to use
[Select]
ssget
list
cons
8
mylistoflayers
edit: or should I use strcat with each element of the list of layers?
Logged
Needs a day job
Reply #3 on:
February 03, 2017, 12:10:57 PM »
If you have a list of layer names, you could do something like this:
[Select]
ssget
list
cons
8
apply
strcat
mapcar
lambda
layname
strcat
layname
list
"Layer1"
" Layer2"
Also be aware you can use wild cards too:
[Select]
ssget
8
"Layer*"
Logged
Coltm16
Guest
Reply #4 on:
February 03, 2017, 12:33:53 PM »
Thanks! I am so close. However, my layerslist is coming out like ("layer1," "layer2,"....) Instead of one long string ("layer1,layer2,layer3....). Thank you for your help!
[Select]
defun
c:stretchfilter
ss i l x ent layerlist
Princ
\n
Select object(s) to include their layers in a stretch command."
if
setq
ss
ssget
":L"
progn
repeat
setq
i
sslength
ss
if
not
member
setq
l
cdr
assoc
8
entget
ssname
ss
setq
i
1-
i
x
setq
x
cons
l x
;endif
;endrepeat
setq
layerlist
mapcar
lambda
layname
strcat
layname
x
princ
strcat
\n
Only these layers will be included in the selection window: "
layerlist
princ
\n
Select objects to stretch by crossing-window or crossing-polygon..."
setq
ss
ssget
list
cons
4
"<OR"
cons
8
layerlist
cons
4
"OR>"
command
"_Stretch"
ss
;endif and progn
princ
;end func
Logged
Seagull
London, England
WWW
Reply #5 on:
February 03, 2017, 12:37:10 PM »
[Select]
apply
strcat
layerlist
Logged
Lee Mac Programming
Twitter
Exchange App Store
Coltm16
Guest
Reply #6 on:
February 03, 2017, 12:44:12 PM »
Awesome, Thank You!
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
