it's a test is not something important.I am trying to see were is the error and why is not working.
The code steps down each cond statement. If the variable "area" = 1 then it will return each conditional statement as true. Code - Auto/Visual Lisp: [Select] (<= area 1000) ;; Area greater than 100 & less than or equal to 1,000Combine it with an and statementCode - Auto/Visual Lisp: [Select] (and (> area 100) (<= area 1000)) ;; Area greater than 100 & less than or equal to 1,000
