Author Topic: Multiple insertion points - original insertion point moves with others  (Read 7431 times)
alanjt
  • Standby for witty remark...
Is it possible to add multiple insertion points (point move parameter) to a block, and when you grip move the block by one of the dynamic block insertion points, it moves the block normally, keeping the true insertion point in place, or does it always just move all objects within the block and leave the original insertion point as it was originally inserted?
« Last Edit: January 23, 2017, 03:40:16 PM by alanjt »
Dropbox
alanjt
Re: Multiple insertion points - original insertion point moves with others
« Reply #1 on: January 23, 2017, 03:40:02 PM »
Nevermind, I figured it out.
In the block editor, you have to create a Basepoint parameter, then add it to the selection of all additional insertion points.
Dropbox
Randall Culp
« Reply #2 on: February 02, 2017, 04:56:19 PM »
AFAIK, you can have only one "BASEPOINT" in a block.  You can have multiple "POINT" parameters but they only work when placing the block.  selecting the block later will only display the one grip at the true insertion point.  Have you found a way to add multiple "insertion" grips to a block??
Randy Culp
(AKA CADaver)
alanjt
« Reply #3 on: February 06, 2017, 03:19:47 PM »
See attached block.
Dropbox
Randall Culp
« Reply #4 on: February 10, 2017, 05:43:18 PM »
huh, ain't that cute
Randy Culp
(AKA CADaver)
alanjt
« Reply #5 on: February 13, 2017, 04:50:06 PM »
If you do it, you have to make sure you create a base point (block insertion point), and select it for each additional point so when you grip move the block from the extra insertion points, it moves the insertion point with the block.
Dropbox
